  • Guests: 46
RoV IW3IPD (63)
01/13 si2030 (62)
Native Animal pictures
Extreme Electronics
Tue May 09 2006, 08:31AM
Extreme Electronics Registered Member #74 Joined: Thu Feb 09 2006, 09:17AM
Bjorn,
that looks to the un-trained eye like a killer duck ? Or is the whale hiding behind the duck ?
Derek
Dr. Shark
Tue May 09 2006, 08:39AM
The Wumpus wrote ...
You can actually get long telephoto reach without going into DSLRs, and at faster apertures too, for an affordable price. E.g., cameras such as the Panasonic FZ30 digicam (Link2 provides 35-420 (35mm equiv) at a constant 2.8 aperture.
Well, I hate to correct you there, but thats not really the truth. While the focal length has been converted to 35mm equiv., the aperture has not been, so you are comparing apples with carrots here. What really counts for good telephoto shots is light, and the easiest way to measure the amount of light you get is the effective aperture. Incidentially, this is how the aperture rating of a lens is defined: Effective aperture divided bz focal lengh. With a 300mm f/2.8 lens, this is a whooping 10cm, but with the realistic 30mm (?) of the FZ30, it is only 1cm, so unless you are in really bright light, you will get motion blur or noise. There is really no alternative to a DSLR for animal pictures, and definitely not a film based SLR.
To get back to topic, this is a crow which poses as a B52 Steath bomber:
1147163802 75 FT8052 B52
Bjørn
Tue May 09 2006, 09:07AM
So what you are really saying is that I can't see and hear the difference between a 5 meter long mammal and a 25 cm bird?
I know that whales are not common on the streets of Nottingham so I have enlarged the picture to hopefully remove any doubt.
1147165637 27 FT8052 Spekkhogger2
Extreme Electronics
Tue May 09 2006, 09:54AM
As I said, an un-trained eye.
You never have a 600mm zoom,tripod etc. when you need them...
Derek
Bjørn
Tue May 09 2006, 10:32AM
That is what i thought at the time but if I had brought a big fat lens I would have taken more than 1 second to focus and shoot and I would have missed it completely.
I can see the resemblance to a duck in the main picture.
The Wumpus
Wed May 10 2006, 12:51AM
The Wumpus Registered Member #325 Joined: Fri Mar 17 2006, 12:42AM
joe wrote ...
Yes, you get a smaller effective aperture with a digicam, but you also have a smaller sensor to expose. Focal length, aperture diameter and image circle diameter all scale down linearly so that f/2.8 will always give you the same shutter speed in the same light for the same ISO sensitivity. It does not matter if it is a tiny cellphone camera or a view camera.
So, in the comparison to the Panasonic, in the picture at Link2 we can see from the lens that the focal length range of this camera is 7.4-88.8. Since the camera is advertised as 35-420 35mm equivalent, this gives a FOV crop factor of about 4.8, which would place the 300mm (35mm equiv) mark at about 62.5mm. The "effective aperture" at this focal length is this 62.5 / 2.8 = 22.3mm. Now glean from the spec in the link the sensor size (7.18mm horizontal) and check the ratio of the effective aperture to sensor width, it is about 3.1. Basically you get the same for 35mm SLR with a 300mm 2.8: (300 / 2.8) / 35 = 3.1
You are right about noise, though. Because the pixels are packed into a smaller sensor the signal contains much more noise for the same ISO sensitivity.
Dr. Shark
Wed May 10 2006, 08:46AM
Yeah, thats basically what I am saying, you cannot get enough light on a small sensor. A DSLR has about 10 times the sensor area, so there will be 10 times as much light striking it in the above example with the "effective" 300mm 2.8 lens. This will cause a signal to noise ratio 10 time (or sqrt(10)? heck!) better than the panasonic. (Dont get me wrong though, I love panasonic, and if I had not just blown my budged on a Nikkor 180/2.8 prime, I would seriously consider a Lumix for general "recreational" picture taking)
Yeah, the on topic animal picture:
1147250594 75 FT8052 Stelze
This one was caught speeding:
1147250699 75 FT8052 Gase
And I am sure I couldn't have done the last one with anything else than a DSLR, because the ISO was up to 1600 for 1/30s at max. aperture. Finland ist a very dark country. smile But still there is very little noise, even after cropping heavily.
The Wumpus
Wed May 10 2006, 09:25PM
The hare is very nice, you have really captured the sense of motion there. It is easy to plead for more sharpness in the hare itself, but knowing how extremely difficult these panning shots are, you did a good job.
Here are some squirrels:
1147296277 325 FT8052 Squirrel2
1147296277 325 FT8052 Squirrel14
1147296277 325 FT8052 Squirrel18
1147296277 325 FT8052 Squirrel4
1147296277 325 FT8052 Squirrel7 Alt
Thu May 11 2006, 12:12AM
Excellent photos wumpus! cheesey Did you use a flash on the squirrel peeping out of the tree hole? I can see the little reflection in its eye, so I guess you did. What sort of flash setup did you use?
I had to go and look up the word "bokeh" on google. It's cool that we have a word for it now smile I guess mirror lenses probably have the worst bokeh ever.
The Wumpus
Thu May 11 2006, 09:48AM
Thanks Steve. I used the Nikon regular SB-600 hotshoe mount flash. Most of the time I tilt the flash upwards and tape a piece of stiff paper or plastic to the flash at an angle, so that the light is reflected and scattered. A simple solution and gives much better light than direct flash. Squirrel eyes don't just get red when you flash them directly, they get a yellow-purplish out of this world glow which looks really strange:
1147340863 325 FT8052 Dsc 0065
This is a problem with most mammals, e,g, cats have reflective retinas, as can be seen here:
1147340863 325 FT8052 Dsc 0905
