  • Guests: 40
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
x-ray fluoroscopes for sale ! Another one up this week!
Sun Dec 20 2009, 01:15PM
EEYORE wrote ...
(Higher voltage resulted in brighter images).
 Kev
EEYORE wrote ...
my cdv700 was pegged on the highest setting! YIKES!
Take care you understand the very non-linear energy response of uncompensated GM tubes, where more can even mean less! smile
plazmatron
Sun Dec 20 2009, 03:35PM
Steve McConner wrote ...
I notice that there's a direct line between the input and output screens on these fluoroscopes. Does that mean that you get x-rays in your eye when looking down them?
Or is there enough tube guts and pieces of glass in the way to stop them, or can the x-ray beam be applied at an angle, etc.
There is something like 30mm of glass, and around 5mm of stainless steel between the input and output windows.
Since it effectively amplifies the image, there is no real reason to use it with x-ray sources capable of penetrating the entire length of the tube. It was designed with low x-ray flux and low kvp in mind.
Thanks EEYORE for your kind review. Do please bear in mind the significant hazards involved in even low doses of x-rays smile
Les
Sat Mar 13 2010, 10:46PM
i did have an idea, use a large B/W ccd sensor (the ones on old school junk 1/3" cameras work well) and put a peltier module on the back to cut down on noise.
might give a better image and also allow for distance viewing for safety reasons.
perhaps also add a collimator on the input side?
regards, -A
