  • Guests: 42
DRSSTC BEAST
raff
Sun Nov 01 2009, 01:32PM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
EDIT:
nevermind.. that was a silly Q.. I wasnt reading the FIRST POST... tongue sorry..
MRacerxdl
Sun Nov 01 2009, 02:34PM
Looking at the driver, he doesnt look to use PLL with VCO . Its only an 74HC14 with antenna feedback
raff
Sun Nov 01 2009, 10:19PM
I was wondering HOW the calculation for primary L and C is calculated...
for example my secondary (including topload) is 200Khz(or something close to that).. so my primary would HAVE be 13Turns/5" Diameter with 10nF cap.. or 9Turns with 20nF... according to teslamap ...
same principle?
Mates
Sun Nov 01 2009, 11:55PM
Hi Martin,
62nF sounds as too high value for a resonant cap in the setup you present on the pictures. I think you should explain how you came to that value...
Also there is the common misunderstanding we run into once upon a time. The double resonant mode as is understood by some of the members of the forum involves also the primary feedback. For you apparently, the double resonant mode means only an extra resonant cap in a classical SSTC setup. Hard to say who is right wink
BTW: Your coil is breathtaking!
Cheers Mates
Mon Nov 02 2009, 02:00AM
Heh, well, it is a solid state tesla coil with a capacitor to cancel the inductive reactance... Like a cross between the two. You will always be in tune with the secondary, but that can change around, making the 'resonant cap' be less than resonant...
Also, 62nf sounds about right. In fact, Steve Ward used 75nf for one of his small drsstc's.
Z28Fistergod
Mon Nov 02 2009, 03:10AM
Z28Fistergod Registered Member #2040 Joined: Fri Mar 20 2009, 10:13PM
raff
Mon Nov 02 2009, 07:09AM
so.. how do we come up with a value for L and C? do you just select (sample) 10turns and an equiv capacitor value?
mmt
Mon Nov 02 2009, 04:17PM
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
wau i was never wonder about those complicated things you all are talking about, I just add a resonant cap to steve's design thats all, and it works great! amazed I have just measured my cap it has 63,8nF.
raff: everything for u want to know is here Link2
all calculations for my cap are here:
TC - Tesla Coil
primary
coil dia: 12,5 cm
wire dia: 2 mm
#turns: 8
height: 3 cm
L: 11,4116170261326 µH
sec
coil dia: 11 cm
coil height: 23 cm
wire dia: 0,2 mm
Toroid: 8,25 pF
#turns: 1092,5
L: 50,8572346041159 mH
F: 188,762356239045 kHz
C: 5,72837677165354 pF
Toroid
outer dia: 19,5 cm
vercical dia of ring: 4 cm
C: 8,25378982923742 pF
LC circuit
C: 62,3 nF
L: 11,411 µH
F: 188,761863274766 kHz
matching cap to freqenci
L primary: 11,411 µH
F sec: 188,76 kHz
C: 62,3012299490451 nF
Z28Fistergod
Tue Nov 03 2009, 02:51AM
mmt wrote ...
Hah, that's funny. So does it have an oscillator or is it solely driven by feedback?
teravolt
Tue Nov 03 2009, 04:21AM
MMT very nice coil. it seems that antena feed back works well for your tesla. this scematic is one of the moast primitive circuits that Steve Ward made and can eat fets with out proper tuning. Did you have any problems building it? have you seen the other shematics that have feedback and interuptor sycronization. I think the reson that your circuit works so well is the fact that you have strong cupling maby .3. have you actualy mesured primary and secondary frequency seperatly.
