  • Guests: 38
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
SSTC - New Secondary = Problems
MRacerxdl
Wed Oct 28 2009, 09:59PM
The secondary winding position is the same =/
Tryed to change GDT Turns, winded on the same core, first has 10 turns, second 20 turns. no difference at all.
Tryed to change the GDT Core from Blue to Black, 12 turns on the new one. No changes too.
That is too weird.
Thu Oct 29 2009, 11:47AM
Parallel two TCs for each GDT input (without 540/9540, maibe too much delay) and use a 1-4 microF for DC blocking cap. Maibe you need more current to switch the fullbridge.
MRacerxdl
Thu Oct 29 2009, 06:10PM
With TC's the output is the same, but the TC's got too hot.
If it was delay, the problems was on Higher Frequencies not lower ones. I found one 10uF 250V Polyester Cap here, its from strobe lamp driver. Its too much for the GDT Cap?
Thu Oct 29 2009, 07:04PM
Dont know really. Experiment with lower values though.
MRacerxdl
Thu Oct 29 2009, 07:14PM
Ok, tryed 10uF on GDT Cap, nothing happens different.
Tryed to increase the Primary Cap (that goes in series with the primary) from 1uF to 3uF, nothing happens too.
Changed the secondary to a little bit higher fres, same thing happens, increasing the topload, decreases the spark size.
I really dont know what is happening here. All things is fine...
Any more ideas?
(PS: One IRF9540 is with a little more heat than the other mosfets. Changed it, but it gets the same heat. But the board is correct. I think that is because I running CW)
Thu Oct 29 2009, 08:06PM
If it is an antenna driver it is very sensitive for the position of the antenna.
Do you feed it from the mains outlet or from an transformer? Maibe higher current capability is needed?
Maibe you changed something in the circuit? Reversing the polarity of the primary and but not also on your GDT primary?
Wrong position of a TC chip in its socket?
raff
Thu Oct 29 2009, 09:53PM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
my 1st SSTC was interrupt driven, now my SSTC with CT feedback runs in CW mode(my interrupter REMOTE is not done yet).. have tried it with 100Vac stepdown transformer rated 500W and ran it with fullbridge smoothed(100uF) for short periods of time (maybe 1-2 seconds)..I could get 2" corona "brushes"... all is OK but I dont push my luck with CW ..Im only using IRFP450
im using 470nF on my gdt primary.. if 1 mosfet IS heating, might be your zener/s in G/S is dead.. or maybe a failing mosfet gate resistor... or maybe a shorted? GDT winding..
MRacerxdl
Thu Oct 29 2009, 10:04PM
The antenna works the same independent of the position.
I am feeding from mains with a variac, but the current when I put toroid is lower than without it. (10A without, and 5A with)...
I tryed to reverse all polarity (GDT and SSTC Primary), if out of phase, it doesnt work at all (and no current is drawn)...
The TC position is fine, it soldered direct on the board I only have one TC4426 that is dual mosfet driver, for handling the IRF540/9540 FullBridge driver for GDT. And it runs very cool.
Raff: Its one mosfet from the GDT Bridge not from the SSTC bridge. The Fullbridge of IRFP250N is running very cool. And I dont have zeners on the bridge at all. Only gate resistors (5 Ohm). All resistors are ok, so is the mosfets on the GDT Driver, and so all the circuit (I tested it)...
