  • Guests: 54
my secondary coil, is this OK?
raff
Thu Aug 27 2009, 02:00AM Print
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
Hi guys,
this is my 1st time winding a tesla secondary coil... mind checking it out for possible problems?
coil length is 8.5" x 3" diameter x 760turns guage 30 magnet wire
tube used is hard cardboard tube measuring 3"dia x 11.5" length
coil inductance (with LC meter) = 12.87 milliHenry
coil OHMic resistance = 60 OHMs
the whole coil
1251338067 2315 FT0 Img 2577
bottom side
1251338067 2315 FT0 Img 2575
top cap.. should I just re-ROUTE the wire directly to the top screw (and not pass the fastening screw/washer)?
1251338067 2315 FT0 Img 2576
thanks in advance for any help/comments/suggestions/flames :)
-Ralph
Austin
Thu Aug 27 2009, 02:33AM
Austin Registered Member #1169 Joined: Wed Dec 12 2007, 09:16AM
you going to coat that thing?
raff
Thu Aug 27 2009, 03:38AM
its already coated ... 3 layers plastic varnish
Thu Aug 27 2009, 04:47PM
The bottom termination looks fine, but the top.. I would remove the screw and washer and lead the wire through a hole or slit made in the plastic cap, you risc corona/break out from the washer. You could use a large enough toroid, but just to be safe avoid sharp points at the HV end.
You secondary resonates around 640kHz, what are you planning to use it for?
raff
Thu Aug 27 2009, 10:07PM
Hi Mads
Thanks for that tip.. :)
ok looks like ill have to remove that screw/washer there. Its main purpose was to hold the top cap, but could also be used as a breakout point<sort of> ... but ill remove it anyway and place a torriod on top..
honestly, I still dont have plans what Im going to use this secondary for.. maybe a small conventional SGTC driven by a ZVS flyback driver , or an SSTC <still not sure what driver/circuit to use either> ...still reading on the hvwiki for info..
some parts are hard to come by here, and budget is a bit tight ill
this is my first time building a tesla coil <and im excited and SCARED as well hehe>
OT: right now im "playing" with the zvs flyback circuit (and getting GOOD results btw)
Fri Aug 28 2009, 04:31AM
It would be fine to build a flyback driven SGTC as your first tesla coil, its simple, gives fine results and can usually be built from stuff you find.
You could just use nylon screws instead, its all about that the only conducting part on the secondary should be the wire.
raff
Fri Aug 28 2009, 06:27AM
yes I agree better start on simpler things 1st.. Im scavenging parts to use as power supply for zvs(will use the STEP-UP transformer found on UPS ,and wire them backwards as step-down) Ive got one here.. the primary measures about 8.6ohms and secondary about .9ohms.. have PLUGED it in 220VAC and I measured its output at about 13Vac.. not so sure about the ampere rating of this thing though.. maybe in the vicinity of 5-6A.. guage of winding is (I think) close to #10?
regarding SGTC, I dont know if I could get one of those NICECAPS for the primary, so I plan on making one DIY...
any site you might wish to recommend?
eniyuki
Fri Aug 28 2009, 10:07AM
eniyuki Registered Member #2148 Joined: Tue Jun 02 2009, 02:22AM
hehe sir rafft welcome sa 4hv.org, grabe mga tao dito pag dating sa tesla coils,.. Hehe lalo na pag nakilala mo si Herr Zapp
Goodluck sir!
Fri Aug 28 2009, 11:31AM
looks good although i really don't like the screws protruding into the secondary at the top of the coil. Get rid of them or at least replace them with nylon hardware.
Herr Zapp
Fri Aug 28 2009, 03:16PM
eniyuki wrote:
"hehe sir rafft welcome sa 4hv.org, grabe mga tao dito pag dating sa tesla coils,.. Hehe lalo na pag nakilala mo si Herr Zapp"
Tagalog????
Herr Zapp
