  • Guests: 24
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
just an idea about static spark gap
eniyuki
Fri Aug 21 2009, 12:54PM Print
eniyuki Registered Member #2148 Joined: Tue Jun 02 2009, 02:22AM
recently, im finding parts for my static gap but i ended up having
a mini radiator from my old water cooled CPU, muffin fan, some hose, and a pump.
suddenly i realize why not use this type of cooling with the spark gap using OIL not water.
heres what im thinking, i dont know how will it behave or how effective this might be but i wanna try it since the items is available so why not try experimenting lol.
its a radiator cooled oil filled spark gap using 2 or more check valve made in brass removing the spring inside for a better flow of oil. any way here it is.
WILL IT WORK?, well its just an IDEA just want it to share...
schematic
edit:
oh my i didnt know how to do the link arrow thingy...
J. Aaron Holmes
Fri Aug 21 2009, 01:21PM
I don't see any immediate reason why such a thing wouldn't work, it's just overcomplicated. In addition, it only provides the cooling, and doesn't directly aid the quenching. I'd recommend looking at the "leaf blower" and "sucker" gap designs if you want active cooling/quenching in a static gap. Very easy to build, and very effective at low and even medium power levels.
Cheers,
Aaron, N7OE
Fri Aug 21 2009, 03:20PM
As Aaron stated, it probably would work, but is overcomplicated. The sucker air gap design is a highly proven design thats been around for decades.
Then again, the DRSSTC would have never been discovered if Steve or Jimmy listened to the regulars at the various Tesla forums who said it wasn't possible or dismissed it initially.
Coronafix
Fri Aug 21 2009, 11:09PM
"The Muffin fan!! The muffin fan! Who lives on drewry lane?"
(Couldn't resist)
Fraggle
Sun Aug 23 2009, 09:26AM
Are you thinking oil for the resistivity? I suggest giving water a try first...
Sun Aug 23 2009, 03:11PM
Fraggle wrote ...
That would create a shortcircuit :)
Myke
Sun Aug 23 2009, 04:18PM
Deionized water seems like a good idea because it has a very high specific heat and good thermal properties. It will only stay an insulator if it is deionized so I would try to avoid it contacting metals. I forget the name of the pump type but it just uses a flexible hose and some wheels to pump the water along.
plazmatron
Sun Aug 23 2009, 11:20PM
Myke wrote ...
Peristaltic pump wink
You can find them in the small store counter coffee/tea dispensers, like in Asda/wal-mart. They are all piped with silicone hose too!
Les
Herr Zapp
Mon Aug 24 2009, 04:54AM
eniyuki -
Jeff Behary (electrotherapymuseum.com) has built at least one type of water-cooled spark gap that utilizes tap water as the working fluid.
See it (and many other very interesting spark gap designs) at: Link2
Regards,
Herr Zapp
Fraggle
Mon Aug 24 2009, 09:15AM
Mads Barnkob wrote ...
Fraggle wrote ...
Perhaps not, clean distilled water might be alright. The peristaltic pumps I`ve seen have low flow rates but if it`s not enough there are loads of all-plastic centrifugal pumps around. As stated above stuff that involves food and drink is the place to look - ice-machines are where I got mine.
