  • Guests: 64
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
gdt problems and suggestions for drsstc driver?
Thu Apr 13 2006, 12:00PM
Steve Conner wrote ...
EVR, when I said +/-7.5V, I was referring to what another poster suggested, driving a GDT with a single driver chip used as a half-bridge.
Ok, i understand.
Dr. Shark
Fri Apr 14 2006, 07:19PM
Nick, I think your gate drive transformer is no good. You should wind it with a single multifilar winding of all the turns twisted together instead of multiple windings, that give a much lower leakage inductance.
the_anomaly
Mon Apr 17 2006, 01:24PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
Thanks for all the suggestions. I have gotten the ucc chips except I accidentally ordered SOIC chip size. I needed a really fine point on my soldering iron to solder these so I attached some small steel wire to the tip.
SmallDrsstcUccchip
The chip when it was done^
SmallDrsstcUccdrivenGDT
wave from gdt^(no dc blocking cap yet)
I plugged the timer into it and set my probe to 10x. I got a nice square wave so I then hooked up to the gdt. I had to set the probe back to 1x and the voltage looks like 3 volts confused . Right now I am using an 8 turn primary and 16 turn secondary’s. I will try to wrap another gdt with multifilar wire and add a dc blocking cap tonight.
Mon Apr 17 2006, 03:17PM
If you plan on operating your DRSSTC at relatively high duty cycles (say >5%), then you will likely need to heatsink those SOIC packages or provide a heatpath for them as they are considerably smaller than the DIP packages which tend to dissipate heat more easily.
To check this, you don't even have to power your bridge up. Just connect everything (bridge, IGBTs, etc...) to your gate driver circuitry, and run it starting at very low duty cycle. Check temp of the driver chips and slowly increase to your maximum duty, checking for heating.
Desmogod
Tue Apr 18 2006, 01:55AM
I've noticed that running a 1:2:2 GDT and IGBT's draw a LOT more than a 1:1:1 and MOSFETs.
I've had to heatsink my UCC's, and change the blocking cap.
Also, don't forget the tantalums over the UCC's either, that should help things along too.
Tue Apr 18 2006, 02:04AM
Desmogod wrote ...
First, you can't compare heat draw when comparing two different devices. Heat dissipation will be dependent upon individual device characteristics and operating parameters.
However, if you had the same device, heat dissipation would increase with a 1:2:2 vs. a 1:1:1 since dissipation is a function of the square of the voltage driving the gate, so for same operating parameters.
