  • Guests: 51
555-based ignition coil, assistance requested
Theodore
Sun Aug 02 2009, 12:37AM
Theodore Registered Member #1506 Joined: Mon May 26 2008, 06:19PM
Ok, so I think another 555 is fried again frown
In the tester circuit it reads continuously "high", and when pin 3 is disconnected from the resistors/LEDs both LEDs come on. Reconnecting pin 3 shuts down the "low" LED and makes the "high" LED come back on.
I changed R1 value to 1k Ohm and the R2 value to 90.2k Ohm. The C1 value was 1nF for the speaker/ignition coil test (calcs to about 8kHz), and a 1uF was added in parallel for the LED test which brings the frequency down to 8Hz. I also tried using a 9v battery as the power supply for the LED test only, and got the same test results.
So, suggestions on how to protect the 555? I kind of thought that since I was using a PC-PS, the internal regulation on it would keep voltage spikes to a minimum. Would just a filtering cap (a few uF?) placed across the supply rails be enough?
I know this is probably irrelevant now, but here is the voltage at the pins:
1: 0
2: 11.2
3: 11.1
4: 12.08
5: 11.9
6: 11.22
7: 12.08
8: 12.08
Suggestions?
Thanks,
Theodore
EDIT: Ok, popped a new 555 in the breadboard, tested with both LEDs and headphones at 8Hz and 8kHz. Both tests worked just fine for extended periods of time with the PC-PS power supply, and the 8kHz tone corresponds to the tone listed as 8kHz on a youtube video. So, the logical conclusion to me is that when hooked up to the coil/FET some sort of voltage or current spike is being produced that is frying the 555s.
So, I know I can produce a circuit that generates an 8kHz signal. Now how can I get that signal to switch the MOSFET safely? Can a gate drive be used to isolate and protect the 555? Hmm, but since the coil and signal generator are running off the same 12V rail...
I dunno, need to think and research on it more. Suggestions and opinions are more than welcome. ^_^
Sun Aug 02 2009, 09:45AM
Theodore wrote ...
This is a known problem, the high current drawn by the coil can put spikes onto the rail that will fry your 555. Most of the schematics you'll see show separate rails for the coil and the driver, and this is why. So try running the 555 off a 9v battery. But don't forget to keep the ground rail connected! There should be two wires going from your 555 to your MOSFET: Gate drive and ground.
Spikes can also feed back through the MOSFET's gate terminal, but this is harder to protect against.
Frosty90
Sun Aug 02 2009, 11:45AM
If your not drawing any sparks from the coil, the voltage across the primary can easily reach a few hundred volts!
You can try putting some large valued zeners across the supply rail, to clamp the voltage to a reasonable level, but they will get hot if the secondary of the coil is left open circuit (no arcs), so you will probably need to use high wattage ones. I've built an ignition coil driver like this before (zeners to clamp the voltage), and it seemed to work quite well.
Cheers,
Jesse
LithiumLord
Sun Aug 02 2009, 02:50PM
LM7812 with full cap bypass and probably a choke to feed the 555, also a TVS across the gate isn't the worst idea. And remember, a gate resistor _is_ required, use like 50 Ohms for the lower frequencies.
Mon Aug 03 2009, 02:08AM
I like Steve's idea to run the 555 circuit from a battery -- the timer is isolated from power section except for 2 wires: GND and gate drive.
Now as for the power section (12V source, ignition coil primary, and mosfet):
Normal operation depends on spikes of over 100V on the MOSFET drain. Uh - you said your fet is NTE2396, looks like its V_DS rating is 100 V ... that's a non-starter in 12V ignition coil app! Get a 400 V fet! Can probably find one in a junk PC power supply.
Also, that's where the spikes automatically get higher if HV output fails to initiate a spark, as suggested by Jesse.
A real spark plug would seem to be an appropriate HV load at this stage.
But the 12V rail should not suffer spikes over 1V if it's well fed. Can you add capacitors between 12V and GND within a few inches of the ignition coil and MOSFET? Say, an Al-can electrolytic of 1000 uF or so -- you can get one from the output section of junk PS. And 1 to 10 uF ceramic cap in parallel?
Ig. coil experts: isn't 8 kHz awful fast? Is 0.06 ms on-time long enough to charge the primary inductance? An 8-cylinder engine at 6000 RPM fires only 400 times per second.
How bout, for first attempt at sparks, set up the timer for on-time of 2 ms and off-time of 100 ms.
Consult 555 app note for how to get narrow positive pulses.
Here is another respectable reference, if not already pointed out here: Link2 Like a previous post in this thread, he recommends a MOV between MOSFET drain and source. And I now see, he recommends starting with frequency higher than optimum (small on-time and primary coil current) then progressively reduce the freq. until output voltage stops increasing.
Theodore
Tue Aug 04 2009, 02:30AM
Wow, thanks for all the responses guys.
For the moment I will go with powering the 555 via 9v battery, although eventually I would like to get a voltage regulator like lithium lord mentioned (and filtering cap bank) so I can run it off one supply and not have to worry about replacing batteries.
Clearly, as said by multiple people, I need a different transistor. Nothing in the local shops is good enough, I may check through some scraps, but will probably have to order some parts through digi-key.
As for the frequency, I used info at the following link:
which states that the resonant frequency of the particular coil I have is 8kHz. Is it correct? I have no idea.
Hmm, interesting. In that link that Klugesmith provided, pin 7 of the 555 isnt hooked up at all. I didn't even know that was a possibility. Lots of info in that link, will take a bit to digest and decide whether to include it in mine or not.
Lastly, I had a few questions:
1. When using a battery to run the 555, am I to understand that both the 12v ground and the 9v ground are going to be connected to the 555 circuit?
2. I know this is silly, but I want to ask it anyway: Earth ground IS an appropriate place to spark the output of the ignition coil to, yes?
3. I also don't understand why the mosfet can see voltages of over 100v, but yet in 'normal operation' there shouldn't be spikes of more than +/- 1v on the supply rails?
4. I see a lot of youtube videos and the like where they are letting the hV output of the iggy strike to the primary taps on the top of the coil. I really don't understand how letting 20kV+ strike the supply rails doesn't fry all the circuitry like mosfets, 555s, supplies, etc.
I think that's about it. Need to find some parts and read some more now. More suggestions and ideas are very much welcome as always. smile
Thanks,
Theodore
Theodore
Wed Aug 05 2009, 05:05AM
Woo, I got a spark!
Unfortunately, its not much more spark than what you get with flint and steel. tongue
I found an IBGT on a scrap PC-PS, datasheet and specs:
600V, 54A
First I tested it by triggering the gate with a 555 but attached the LED/resistor array to the collector, and started with ~8Hz. I found that having a 10k resistor from gate to ground really dampened the oscillation of the LEDs. Also, I found that using a 9V battery as the PS would work, but again the oscillations were much weaker. I fear that I need a stronger voltage to properly "turn on" this component, I think the datasheet says 15V.
Then tested it at 8kHz, using headphones. Also worked.
Mounted the IGBT properly on the heat sink, had to adjust my fittings since there was some left over traces of solder on the pins. Hooked everything up, including 9V and 12V sharing a common ground.
And I got "sparks". More like a twinkle across a few mils of air to earth ground, but its something. Tried adjusting the frequency down to 3 or 4kHz, didn't really get anything more out of it. Added a 470uF, 220V cap scrounged from a laptop PS across the 12V rails, and the sparks definitely were brighter, although they didn't really seem to want to jump much further.
I think that if I:
1. Find this coils resonance frequency.
2. Add a 2000uF cap bank to the 12V supply.
3. Find a way to better drive the IBGT.
I might actually be able to produce 3-5cm arcs with this. However, I:
1. Don't have an oscilloscope.
2. Need to buy the caps.
3. Haven't a clue how best to accomplish this.
Suggestions welcome as always! cheesey
My sincerest thanks,
Theodore
Wed Aug 05 2009, 05:52AM
Theodore, Ive made a few changes to your circuit diagram
1249451515 162 FT72923 Untitled
The 100 ohm can be 10 ohms to 220 ohms
The 10uF capacitor can be 10 uF to 1000 uF, 16 V rating or more.
When/if it works you can add a 10 kohm variable resistor in series with the 1 kohm that I added.
Wed Aug 05 2009, 07:32AM
Sulaiman, what is the purpose of the 100 ohm resistor and the RC across the coil? We're trying to produce the highest voltage "kick". And with the 100ohm resistor, the output will be almost nothing.
The cap on the pin 5 can be changed to 0.1uF to better protect it from interference (I do this anyway).
Also don't forget the possibility that the coil might be fried.
Theodore
Wed Aug 05 2009, 03:51PM
Hmm. Well, I thought I would post what I am using right now, that is semi-sorta working:
1249487253 1506 FT72923 Rightnow
