  • Guests: 82
Designing a DRSSTC from scratch
magnetomotive
Sat Jul 18 2009, 07:36PM
magnetomotive Registered Member #267 Joined: Mon Feb 27 2006, 09:44PM
Those are some great links Anders M, thanks.
Steve-
I was referring to the maximum average power from the wall (I shouldn't have said peak). I've been thinking about how I want to soft start the coil. I will probably use a variac until I get the coil working, and then add a soft start circuit. Would a 120V, 10A variac be fine for a coil like the mini brute (1200 W) or should I get something with a higher current rating? I don't want to overload my variac, or be blowing fuses all the time.
Wolfram
Sat Jul 18 2009, 11:28PM
You should be able to precisely control how much current the coil draws from the power line by varying the BPS/on-time, so you can always keep it under what the variac is rated for.
I've also heard that variacs can be pushed to twice the rated current for some minutes, so you have some headroom there.
I don't know if you have to do any derating of the variac due to the non-unity power factor of the DRSSTC leading to increased I^2R losses in the variac. Any opinions on this?
Anders M.
Mon Jul 20 2009, 07:17AM
Anders M. wrote ...
Yes, the power factor can be terrible, like 0.5, because of the large DC bus capacitance. It actually gets better at variac ratios away from 1:1 because the leakage inductance of the variac smooths out the current pulses.
In practice, though, nobody seems to run coils continuously at full power for hours, so it works out OK. But with DRSSTCs you'll find yourself compelled to turn it up until something blows, so might as well make it a cheap part like a fuse.
magnetomotive
Sun Jul 26 2009, 03:17AM
What is the minimum requirement for an oscilloscope and probes to test the circuits of a DRSSTC?
Sun Jul 26 2009, 09:48AM
Oscilloscope: The cheapest flea market special you can find, because you'll probably damage it sooner or later.
Probes: Two x10 probes at a minimum. I also like to have a x100 high voltage probe, because if you want to scope the output voltage from your inverter, it's over the rated maximum for most x10 probes.
Some ferrite-cored current transformers are also handy. I have two, one with 33 turns and 3.3 ohm burden (1 volt per 10 amps) and another with 33 turns and 0.33 ohm burden to give 1 volt per 100 amps. I fitted BNC sockets to them, so I can just plug them straight into the scope with a BNC cable.
magnetomotive
Tue Jul 28 2009, 02:57AM
Steve McConner wrote ...
How many MHz for the oscilloscope?
TheBoozer
Tue Jul 28 2009, 08:51AM
TheBoozer Registered Member #1535 Joined: Wed Jun 11 2008, 11:37PM
20mhz is a good start. You'll be able to see if your tank is ringing up properly. You'll be able to measure how much current is flowing in the tank circuit when using a CT to feed your probe. You'll be able to verify proper interrupter operation. You'll be able to zoom in and see how accurate your zero cross is on a low frequency coil.
