  • Guests: 74
Arjan EMM (52)
12/31 Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
GU5B VTTC project
Wed Jul 22 2009, 05:50AM
Yes, I keep a little free space on the wood plate with the RC network for a staccato circuit, so it can be added later.
Sat Jul 25 2009, 06:49PM
FIRST LIGHT
-40 primary turns
-21 feedback turns
-1.46 nF @ 18 kV primary cap
-1.36 nF grid cap
-11 nF filer cap
-5 microF doubler cap
The final setup:
Th
Primary cap
Th
Coils:
Th
First light: 60 cm sparks to a grounded copper rod.
http://www.youtube.com/watch?v=wUbfZzKTpiw&feature=channel_page
I am using 2200 V output MOTs in my doubler. I will try to find some 2500 V output ones, so maibe I will have a few inches more in spark lenght.
brtaman
Sat Jul 25 2009, 07:27PM
brtaman Registered Member #2161 Joined: Fri Jun 05 2009, 03:36PM
Amazing coil, vasil!
Those are some very nice sparks. Do you plan on adding staccato? How much more do you think you can squeeze out of that monster tube?! Gonna start searching the Internets for a GU5B. :O
Again great work, your project is really coming together.
Sat Jul 25 2009, 07:32PM
No staccato yet, have to see how much can get out without it.
I have already a plan to modify the power source to get more juice.
Dr. H.
Sat Jul 25 2009, 09:57PM
Good day Vasil
nice looking coil. Congrads on first light. :)
Looking forward to breaking the 1m barier. With that tube you shoud be able to pull double the size of those streamers. Start tinkering with the feedback coil and the primary circuit.
Keep up the good work sir.
Cheers.
Sun Jul 26 2009, 06:53AM
Are you sure?
For, let say 3600 W on plate, the Freau formula predicts only 0.5 * sqrt (3600) = 30 inches sparks for a well balanced system.
Maibe I can break 1 m but it would be a risk for the tube.
Sun Jul 26 2009, 10:01AM
Nice work Vasil! :)
Spark length is determined by peak power, but plate dissipation is determined by average power. So you can get longer sparks without damaging the tube, by increasing the peak power without increasing the average.
This is what the staccato circuit is for. If you set your staccato to every other cycle (25Hz PRF) you can now retune your tank circuit for twice the RF power. Or increase the HT voltage by a factor of 1.4, or whatever.
Given the size of the tube you're using, I think the power supply would burn out before the tube does! :O Just watch out for overheating of the control grid. You can't easily see it glowing because of the metal envelope and bright filament nearby, so a grid current meter would be a really good idea.
Dr. H.
Sun Jul 26 2009, 05:26PM
Good day Vasil
YES - I am absolutely sure - if you look at my thread about the double GMI-7 coil you will see that I am using two MOTs in series, and the plate dissipation rating for each of the tubes is like 180W and I am hiting the 1m (40inch) ceiling without any problems (and the system is still not tuned because have problems with flashovers.) And also have in mind - I do not use staccato (for now that is).
Cheers Dr. H.
Sun Jul 26 2009, 05:55PM
Thanx
From datasheet I can not know a few things:
http://www.tubes.ru/techinfo/Broadcast/gu-5b.html
What is the max power dissiaption on the grid? The max grid current?
How much is the peak voltage supported by this tube? If I increase slowly the plate voltage are the eventually breakdowens fatal for the tube?
Where do I have to put the A-meter (on the grid or between RC network and negative pole? Have to use a DC A-meter or AC one? (didnt use anything like that before).
This is the actual power source schema (4 MOTs in phase and doubled):
Th
I will modify this to get twice voltage:
Th
I would not go above 7 kV (at 7.2 kV an 833 suffered breakdown in Freau VTTC magnifier) though for safety reasons for the tube. Thats under 140 V on variac from my calculations.
Sun Jul 26 2009, 08:30PM
Dr. H: If I remember right GMI-7 tubes are designed for extremely high pulse currents in radar modulators. They have huge oxide-coated cathodes that can deliver several amps of current. So it's not surprising that they can generate high peak RF power and colossal sparks. The peak power capability of Vasil's tube might well be less, even if the average power capability is greater.
As for all those questions, we'll need to hope that someone who reads Russian comes along. :( I do know that the grid current meter should be DC, and you insert it in series with the grid leak resistor at the grounded end.
