  • Guests: 47
Bill G (65)
Overclocked (38)
Edi (32)
09/21 Bill G (65)
09/21 Overclocked (38)
09/21 Edi (32)
Cool find: Home made toroid winder
Mike
Sun Jun 21 2009, 10:54PM Print
Mike Registered Member #58 Joined: Thu Feb 09 2006, 05:40AM
I was reading hack-a-day and noticed this post:
A guy made a toroid winder from the tire of a kids bicycle. The actual topic is here:
Link2 (ignore the site name heh )
And a video of it in action is here;
Seems like something I would love to have... I really hate winding toroids heh.
Mon Jun 22 2009, 01:13PM
I have some 1930s designs for home-made coil winders - including two different wave-winding machines - which are the kind of thing made with wooden cotton reels, a great deal of ingenuity, and accurate carpentry.
Hon1nbo
Mon Jun 22 2009, 03:31PM
I think this was posted in another area on the forum yesterday... General Science I think
Mike
Thu Jun 25 2009, 08:32AM
DaJJHman wrote ...
I actually posted mine about 30minutes before that topic :p Anyway, I already said a mod could delete this topic since the other one got more comments smile
Herr Zapp
Fri Jun 26 2009, 02:25AM
Harry -
On the topic of "winders", please take a look at the conventional multi-section, "pie-wound" RF choke pictured below. Note the "pseudo-basket-weave" appearance of the windings, when viewed from the side of the "pie". Each pie is oriented 90 degrees to the centerline of the former that the pies are wound on.
I'm trying to figure out exactly what winding process is used to generate these pie sections. It looks like the axis of the former is oscillated back and forth in a single plane, in a fairly narrow angle to generate the angle of the windings. However, I think there is another motion that must be added to get the "basket-weave" effect. If the former were just being oscillated in a single plane, the entire pie would just be a thick disk at a slight angle to the centerline of the former.
You mentioned that you had several designs for coil-winders; anything that generates "basket-weave" pies?
Regards,
Herr Zapp
Wound Rf Choke Side
Wound Rf Choke End
Bjørn
Fri Jun 26 2009, 10:01AM
It looks like the common winding method that makes stble sides: Link2
There are no complicated movements, just back and forth: Link2
You need to wind at a specific angle with an exact distance between each turn so several turns end up side by side to fill up each layer.
