  • Guests: 68
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
"Thumper"
Sat May 15 2010, 08:11AM
Daniel Uhrenholt Registered Member #125 Joined: Fri Feb 10 2006, 01:52PM
I didn`t see your post Mads.
We can arrange a little Danish Thon this summer:-) Be sure to bring a coil or two, I will find a place where we can make sparks all day long!
Cheers, Daniel
Sun May 16 2010, 09:56AM
Daniel Uhrenholt wrote ...
Cheers, Daniel
Got my VTTC and SSTC3 that lives, the SSTC2 is dead for the moment, a primary flashover killed some windings on the secondary :(
A weekend would be the best for me, all vacation is already booked up :)
Thu May 20 2010, 07:57AM
Monday was a bit more busy then expected frown First year at the uni also sucks up time rather fast. So I didn't get the copper busbar done. But I did take a pic of how things look now. Think you can allready guess how the busbar will look from the picture.
52
Don't know when I'll have time to get working on the copper again. Lots of stuff to do and some problems at home that need my attention.
Thu Jun 03 2010, 10:45AM
Generous fillets applied to all, otherwise protruding, corners, are the trademark of a CNC machined product.
But I don't have that, so my fillets are applied, retrospectively, the good *old school* way.
This is how it is done:
1275559584 205 FT68820 Fillets
A suitably radiussed backup slug, the descent of the file is effectively controlled.
I want safety, but I don't want to be soldering all night.
When looking at soldering 200 bleeder resistors, a down and dirty solder jig is mandatory.
Shut up, get done with it, and solder!
1275559895 205 FT68820 Solderjig
2 x 10M for a 30sec time constant, going easy on the Q tongue
And finally some CAD porn: Huwow, a lot of hours must have gone into that!
1275560071 205 FT68820 Udklip1
I am about ready to apply Conducto Lube to the mating surfaces of the sliding Pulsed Kiloamp connections, and am modestly proposing first light this first coming Sunday.
Cheers, Finn Hammer
Coronafix
Thu Jun 03 2010, 12:23PM
Beautiful work Finn, especially the radiusss.
Thu Jun 03 2010, 08:40PM
Coronafix wrote ...
Thanks, Coronafx
And now the circuit is closed, just waiting to get pulsed by the motor
cheesey
1275597404 205 FT68820 Circuitclosed1
shades
1275597444 205 FT68820 Circuitclosed2
amazed
Cheers, Finn Hammer
Thu Jun 03 2010, 08:52PM
Have fun powering this beast up. And keep us posted.
Coronafix
Thu Jun 03 2010, 10:59PM
You'll probably want to keep changing toploads on it so you can keep tuning it. :)
Fri Jun 04 2010, 05:09AM
Coronafix wrote ...
Actually, I doubt the topload is going to be changed, unless I can muster enough gumption to make a larger one. shades
The reason that I made the cap configurable is, that I want to be able to search for a possible sweet spot, where the L/C ratio is different. Like, better sparklength/pri_current ratio
Wow, now so close to the moment where i watch the scope, while sweeping past the sweet spot, recording it for you all to see.
Cheers, Finn Hammer
Fri Jun 04 2010, 06:05AM
Nice work Finn,
I can`t wait until Sunday, where we will see if all of this hard work works as we planned:-) Yesterday I soldered the last PCB for the motor controller, so this afternoon I will write the last code for it...
See you Sunday!
Cheers, Daniel
