  • Guests: 37
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
SSTC feedback antenna clamping diodes
Mon Apr 20 2009, 08:59PM
Germanium diodes can be good. If I'm right Steve Ward used 1n60 before. 1n4148 has proven itself to be a worthy clamping diode, but it can't stand everything. Personally I like to use fast low voltage drop Schottky diodes.
MRacerxdl
Tue Apr 21 2009, 03:05AM
The Germanium diodes usually have 0.2V to 0.4V of Voltage Drop, and Silicon ones is 0.6V to 0.8V... That made the Clamp voltage Vcc+0.6 for positive cicles and GND -0.6 for negative cicles. If you see the 74HC14 Datasheet, 5,6V is close to the maximum voltage input for it and -0,6V is close too. But since the 74HC14 is a Low Voltage CMOS, they have internal clamping diodes that will do the job too...
About the ignition coil running with antenna feedback, I made this thing once, but it doesnt work good. The better thing you can do is use a DRSSTC like feedback but instead using a CT, you wind a Feedback on the flyback core. It might work.
