  • Guests: 38
Plasmasonic II build
quinn
Fri Nov 06 2009, 01:54AM
quinn Registered Member #2460 Joined: Thu Nov 05 2009, 12:18PM
Thanks for the reply Dr.
But i don't understand how to adjust the duty cycle to 25% with no signal input. With no signal input the duty cycle seem to be about 33% on oscilloscope and after i adjust R24 it never changed. Is there anything wrong?
quinn
Mon Nov 09 2009, 11:31AM
When i was adjusting the circuit i just got different output signals from the gates...and which one is right
1257766290 2460 FT67963 Img 5079
Mon Nov 09 2009, 04:11PM
quinn wrote ...
The bottom one. Thats 25% duty.
Colin 99
Mon Nov 16 2009, 01:44AM
Colin 99 Registered Member #192 Joined: Fri Feb 17 2006, 03:08AM
Indiana,
I think the reason you blew Mosfets it that you applied to much voltage to the bridge. If I remember, 240 volts or so input was the maximum, Dan can verify this.
I've blown a few gate drivers too, I also had one that was non-inverting that was suppose to be inverting. That blew a couple up too.
My picture on the left is my Tesla coil being driven with the Plasmasonic 2 board, The spark discharge was 2.5 to 3 feet tall. I was drawing enough power off of 120v circuit to blow the 15 amp breaker.
you'll get there with some more experimenting.
I also ran your coil dimensions through WINTESLA and it gave me the resonant frequency of 489 khz without a top load. I'm not sure what your measuring?
quinn
Mon Nov 16 2009, 07:22AM
[MOD EDIT] - Corrected double post - Watch the double posting!
Finally I got the right signal by adjusting R24,maybe i did something wrong before.
And I have a queation about the schematic.Is there connections at the marked place shown in the picture?
This's the picture
1258356138 2460 FT67963
Mon Nov 16 2009, 12:22PM
Yes, there are connections at all those points.
quinn
Mon Nov 30 2009, 07:41AM
Dr.
I conencted all the wire at those place,but when i connected the wire at point 1,the output signal seem not right.
So should the caps be series connected to the E1-E3 input or parallel connected with the fets separately?
Mon Nov 30 2009, 07:10PM
(2) and (3) are connected, but yes you are correct. Node (1) is not connected. Its correct on the schematic on how it should be wired.
Colin 99
Sun Dec 27 2009, 11:15PM
Where can I get some spare MOSFETs for the PlasmaSonic 2 board?
I was thinking of buy 8 of them in case I have a failure.
thanks,
Shaun
Mon Dec 28 2009, 04:02PM
Failures are extremely RARE with the Plasmasonic. Mostly because you are running CW with relatively low currents and no peak currents like you would see with a DRSSTC.
However, for spares you can get some from Future Electronics or Farnell, etc... Or even EBAY.
Also, you don't need the specific MOSFET. They can be any of the MOSFETs rated for more than 500V from IXYS in the same type package. Such as IXFN24N100, IXFN44N50, IXFN48N50, etc...
Dan
