  • Guests: 60
How a pole transformer is made
Renesis
Wed Apr 15 2009, 08:25PM
Wired? As in... how? How it is hooked to the bushings? XD
No, i was confused on how they could get three phase power out with only two phase power in. But 3l3ctrici7y explained that the third connection is the center tap. I must admit now that i know, that is quite obvious cheesey
Thanks again
Plasma Lover
Thu Apr 16 2009, 10:43PM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
[quote]
[quote]
Also, in televisions around the CRT they use that 'thick wire' that surrounds the CRT, which is insulated in none other than electrical tape. Take the tape off, and it is (for a large CRT) hundreds of feet of wire! BUT, this is also aluminum from the wire that i have seen. MOTs and TV's use so much wire, they just use aluminum to cut down on cost, while till working alright.
[/quote1239921776]
The 'thick wire' that you're talking about in a T.V. is actually called a degaussing wire. I just thought I'd interject that.
