  • Guests: 44
kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
12/20 Duality (16)
Large DRSSTC [update]
Linas
Tue Jan 11 2011, 01:08PM
Small update:
Prediktor pcb ( just in case, better use driver on pcb with mask)
And little bit more advanced driver for IGBT with saturation detection and fast optocouplers to synchronize protection :)
1294751328 1143 FT66676 P1570501
1294751328 1143 FT66676 P1570502
1294778124 1143 FT66676 P1570510
1294842342 1143 FT66676 P1570569
1294842342 1143 FT66676 P1570571
Now is the big question:
What should i do with desaturation error signal ?
disable interrupter for 1s or maybe wait time larger than half of period, and if i still getting error close all IGBT for some time like 1s ( forced close ) ?
What should i do ?
Dzejwor
Wed Jan 12 2011, 07:39PM
Dzejwor Registered Member #2750 Joined: Sun Mar 21 2010, 08:47PM
Very nice work - as usual :) I can't wait to see efects of this coil with THIS monsterbridge. How large MMC you plain to use ?
Linas
Sun Jan 16 2011, 05:19PM
And here is idea, how to stop bridge. But now question is for how long, or maybe stop and use reset button to continue ?
And same driver on new pcb ( i don't like idea that driver is on pcb without solder mask )
1295198356 1143 FT66676 P1570622
1295198356 1143 FT66676 P1570615
Linas
Mon Feb 28 2011, 03:12PM
Bus bars layout shades
1298905923 1143 FT66676 P1590457
Electroholic
Mon Feb 28 2011, 04:07PM
Nice, how are you going to connect the cap buss bars to the bridge buss bars? looks like you just have a T there.
I would probably use a lap joint if they are to be hard soldered together.
Linas
Mon Feb 28 2011, 05:50PM
Electroholic wrote ...
I will solder it smile
Linas
Fri Apr 01 2011, 09:11PM
Small update:
Bridge is working, saturation detection is working, but again, prediction circuit struggles to work cry
1301692246 1143 FT66676 P1590482
1301692292 1143 FT111729 P1590494
MRacerxdl
Fri Apr 01 2011, 09:42PM
Very good work! Congrats :D
I cant wait to see sparks from it :D
Linas
Mon Feb 13 2012, 07:33AM
can some one help me out.
Predictor just don't work for me. i can't get even into oscillation, i get just interrupter signal in output ( testing around 100-150V into the bridge)
if i connect generator and disconnect shunt resistors i am getting signal out of my UCC's, and if i connect old driver ( just 74HC14 and 74HC109N) i am getting into resonance with no problem.
I have basically same circuit as Finn , just using 0,7uF MMC and +-12V for AD790 (not +-15v)
Bridge also the same, (full bridge of CM600)
And now even if i use some ultra-fast IGBt and simple LC circuit like Finn did in test, i can't get no oscillation
any idea why it's happening ? ( That would help a lot )
Gregory
Mon Feb 13 2012, 03:18PM
You need to give us more information.. your inductor, shunt resistance... if you are using a capacitor in series with the input of the AD790, like a 100n capacitor it can be your problem. the capacitor can get charged at the and of the first burst and current will no flow in it at the next bursts, so you lost feedback and no get the start. try put a resistor in paralel with the capacitor, like 10k
