  • Guests: 47
kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
12/20 Duality (16)
Large DRSSTC [update]
Linas
Sun Oct 24 2010, 08:05AM
Last test with doubler, but it doesn't look much better than running single phase without doubler, so i will try 3 phase
Wed Oct 27 2010, 06:06AM
Did you measure the output voltage of the doubler whilst the coil was running. Looking at the coils output I'd say it was sagging under load. Awesome coil. Hope you'll keep throwing bigger and bigger arcs without blowing anything up smile
Linas
Thu Nov 04 2010, 09:11PM
Ok, i don't know why but my bridge just blow away.
so i get new parts for bridge, it will look like Finn bridge, just more caps, and SS driver for IGBT
1288905116 1143 FT66676 P1570419
Thu Nov 04 2010, 10:48PM
Shame your last bridge blew. But from the looks of it your well stocked up on some spare Si smile Never stop making those arcs bigger.
Linas
Fri Nov 05 2010, 08:03AM
Dalus wrote ...
it was running 300us and 500Bps, 3-Phase, coil was literally arcing ( like Jacob's Ladder ) to ground, and sparks even at day was very bright.
Investigation was unsuccessful, because i have one jammed power Fet in IGBT driver, also powers supply channel for this driver is not working now, noticeable high current pass marks to power supply between both low sides IGBT. (it look like explosion force some how let +HV flow to IGBT driver's)
And it was two explosions, one small, and after second big one in right side IGBT
1288944203 1143 FT66676 P1570410
Killa-X
Fri Nov 05 2010, 03:00PM
Nice to see an inside of an IGBT module! Looks like you put a bit of power into it... Project looks like it's coming along good, nice work =D. Any set-goal to have it finished..?
Luca
Fri Nov 05 2010, 03:30PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Linas wrote ...
Well, 300us ON and 500 BPS means a duty-cylcle of 15% which is really high! Probably you had a failure due to the excessive rms current in the primary circuit.
You should avoid such high BPS...
Regards,
Luca
ScotchTapeLord
Fri Nov 05 2010, 10:06PM
Ouch. The long on times are probably being very hard on your mmc's voltage rating.
*I have nightmares that involve catastrophic mmc failure*
Linas
Sat Nov 13 2010, 09:36PM
Here is new bus bars layout
Yellow is bottom layer ( directly on IGBT output )
Red is supply with at least 1.5cm spacer ( very very fat spacer, 324mm^2 )
On top we see 20uF 800V high current snubber, and will be smaller 2uF 1000V below .
And at right side 800V 4700uF Rifa capacitor ( but two in series , and two in parallel , so it's 1500J)
now just need somehow get M8 brass bolts ill
1289684170 1143 FT66676 12
Sat Nov 13 2010, 11:29PM
Linas wrote ...
Stainless is good too!
Cheers, Finn Hammer
