  • Guests: 48
kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
12/20 Duality (16)
Large DRSSTC [update]
Linas
Fri May 07 2010, 01:10PM
update.
I made new driver for DRSSTC "Prediktor"
It is Finn and Steve design combo (predicting part and some OCD from Finn, rest from Ward driver)
Still waiting for AD790 chips so i can't tell how it works ;)
as you can see i have very dense design of pcb smile
1273237845 1143 FT66676 Prediktor
1273351288 1143 FT66676 Img 6656
Linas
Wed Jun 30 2010, 11:59AM
Here is pcb files for DRSSTC, maybe some one found it useful.
Predictor still need to be tested, i will post when is fully working..
]drsstc.zip[/file]
Matt Edwards
Sat Jul 03 2010, 02:40AM
wow
Sun Jul 04 2010, 05:37PM
Linas wrote ...
Linas,
I am wondering what program you use, that produces files with .lay extension? cry
Cheers, Finn Hammer
Linas
Sun Jul 04 2010, 05:51PM
Hi finn.
Original program is sprint layout 5.0
hrrr, still no luck with predictor, it's quite hard to make it work frown
1278266428 1143 FT66676
Mon Jul 05 2010, 06:43AM
Linas wrote ...
Hi finn.
From the scopeshot it would appear that you have got it to oscillate, right?
Cheers, Finn Hammer
Linas
Mon Jul 05 2010, 11:26AM
OK, Here is interrupter times:
Ton 6-340us
Toff 600-7800us
max duty cycle is 36%
OCD works nicely, but after rectifier i get just positive peaks, well, maybe is not a big deal
Only thing is not working is prediction, but maybe is because i can't get clean waveform even at perfect zero crossing...
1278329313 1143 FT66676 F0008tek
1278329313 1143 FT66676 F0009tek
Mkey,a little bit more tuning and i get waveform like it should be. Now just prediktor part left....
1278347885 1143 FT66676 F0010tek
1278347885 1143 FT66676 F0011tek
Linas
Wed Sept 29 2010, 08:41PM
it look like predictor is working a little bit, but Steve original design is also very close to predictor waveform at 60V
1285792887 1143 FT66676 Pred1
1285792887 1143 FT66676 Sw
Fri Oct 01 2010, 09:10PM
Linas,
Thanks for posting measurements.
I see that you have a TPS with built in differential inputs, so I suppose that I don't have the option of questioning the bandwith of your probes?. wink
It would be interesting to see the rising edges on an expanded timebase, and a current derived signal too. 50% percent overshoot is not the trademark of a properly adjusted Predikter.
Cheers, Finn Hammer
Linas
Sat Oct 02 2010, 07:09AM
Well, here is another picture of rising and falling fronts.
It's not 50pr overshot, it was measured DC with AC coupling, so it says it is 29V but peak to peak voltage is ~61V.
Overshot is like 5-10Vmax
1286003381 1143 FT66676 Pred2
1286003381 1143 FT66676 Sw2
CT is 300T on 3E25 corewith 0,5mm vire, R=2Ohms
and here is signal with old configuration Steve driver with 300ns on delay:
1286003712 1143 FT66676 11
1286003713 1143 FT66676 22
and here is video of best tuned at various voltages
And Uge is perfect, no overshot at 1000A :)
And here is some Gate and current signals
1286781569 1143 FT66676 P1570340
1286781569 1143 FT66676 P1570338
1286781569 1143 FT66676 P1570337
zero in scope is for current and Vge (because i have -8V negative shutdown)
