  • Guests: 54
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
My first zvs attempt
KLH
Fri Apr 03 2009, 10:14PM
KLH Registered Member #1819 Joined: Thu Nov 20 2008, 04:05PM
Arcstarter wrote ...
Better filtering will indeed increase power throughput and give you thicker arcs. It seems it can also reduce flyback heating. The driver looks good :). I cannot view the video *murmurs something about windows media player*.
I think that the reason that the flyback heats less with better filtering is because there are less AC winding losses and core losses. A lot of flybacks I've seen use a single strand of thick wire for the primary. When the flyback is operated in the discontinuous mode (and the operating mode can be hard to control), there will usually be high AC winding losses. I recommend replacing the singe-strand wire with Litz wire or thick copper foil / strip.
The filter inductor looks very nice; it looks a LOT better than a lot of DIY toroid inductors I've seen. Do you happen to have its dimensions (outer diameter, inner diameter, height)? I would like to see the characteristics of this inductor.
Zee
Thu Apr 16 2009, 05:06PM
Zee Registered Member #877 Joined: Tue Jul 03 2007, 09:15PM
Replaced the two filtercaps with one bigger 50V 10000uF cap and also added the second secondary of the transformer to double the voltage. Now the 400V cap heats up even faster. Gotta find/do a replacement for it too.
The toroid was ripped from a dead PC PSU and re-wound with a wire from another toroid from the same PSU. Seems to be a white one, painted in yellow. I got there either 31 or 32 turns. The inner diameter is 13,5mm, outer diameter 23,5mm and height 9,5mm.
3l3ctrici7y
Thu Apr 16 2009, 06:07PM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
Zee; I just watched the video, and that is amazing. The pop sound it makes when the arc forms and extinguishes is awesome :)
I used mplayer, and it worked perfectly. Link2
Zeus
Wed Oct 21 2009, 12:13AM
Zeus Registered Member #2316 Joined: Tue Aug 25 2009, 03:04AM
Overkill is not possible with hv. Also I can't watch you video (also murmurs something about windows media player).
Zee
Wed Oct 28 2009, 07:44PM
Been a while since I touched that thing. Updated caps and doubled the voltage at one point.
http://www.youtube.com/user/X0reZ for few videos of it spewing out some arcs. Nothing impressive tho.
