  • Guests: 18
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
QUAD-MOT Tesla Coil
Alexandre
Sun Mar 15 2009, 05:16PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
After some tests with my 8Kv NST, I looked to my coil and my QUAD-MOT power supply, and I thought, Why not put the primary 5KW of my coil?
Said and done, Arm all SETUP, using my RSG and a bank of old capacitors..
Specs:
Secondary - 40cm 24AWG wire
Primary - 13 turns of 5mm tube
Capacitor - 30Nf@ 19kv
Power - QUAD-MOT
RSG - 3450 RPM motor
Bigger toroid - 13cmX40cm
Some adjustments and some capacitors burned, it approximately 1M of ARCS in the air amazed
Pictures:
1237137189 1228 FT0 Pict0192
1237137190 1228 FT0 Pict0193
1237137190 1228 FT0 Pict0195
video in HD shades
theju
Sun Mar 15 2009, 06:23PM
theju Registered Member #1445 Joined: Tue Apr 15 2008, 01:25PM
nice ^^
but i would add a breakout point so that the streamer don´t hit the secondary or primary
what type of capacitors are you using?
fkp? mkp?
greets
Alexandre
Sun Mar 15 2009, 07:15PM
the capacitor bank is a series of 30 capacitor of metalized polypropilene film, each cap is a 1uF 630V
total - 33nF 18900V
Correction is 19kv not 25kv
