  • Guests: 46
Strange cap charging issues
Sat Feb 28 2009, 09:00PM
Coherent wrote ...
I wonder if a rectified 3kv NST would do a better job.
Yes it will. But you should still use a charging resistor in front of such a big capacitor, but a much smaller value will do. When the capacitor is totally discharged, it 'looks' to the power supply like a dead short, so there is a high inrush current which you want to avoid. A charging resistor will limit the inrush current to a manageable size.
As a man who now understands about RC Time Constants, you'll be able to calculate all this yourself! Good luck! smile
Sat Feb 28 2009, 10:19PM
Not too sure, but you may not need the resistor. NST's are current limited, made for a continuous short. The capacitor is too large to have any resonating effects, so if should pull what it normally would in the event of a short.
Fraggle
Sat Feb 28 2009, 10:45PM
Lol, just checking :D
Coherent
Sun Mar 01 2009, 12:56AM
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
Well rather than screw around with resistors I decided to just make a mini spark gap to charge it. I used two nails with the tips just barely not touching and it works great now. The power supply is already limited to 5ma so it really shouldn't need any additional current limiting. Either way the cap works great. Diodes turn into firecrackers, wires explode and it can instantly vaporize small strips of tin foil. There's an extremely loud bang, bright flash and nothing left of the foil but a white cloud of smoke. When it gets nicer outside I can try blowing fruit to bits ;)
