  • Guests: 75
current limitation
Sun Mar 22 2009, 03:51PM
some3 wrote ...
I was thinking of a other maybe possible solution What obout PWM controling the transformer.
This will work only when you already have an inductance in the circuit which limits the current to a safe value, then you can use a SCR/TRIAC phase angle controller to vary the current.
hotcrazyfruit
Wed Mar 25 2009, 02:00AM
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
i know im a bit late on this, but if you used the primary of a separate transformer, you could use it as an inductive ballast on the primary side of your TC transformer. im doing this, only for my capacitor charging circuit. use the equation
Y=2piFfL
with
Y being inductive reactance (or ohms)
2pi (2*3.14, or 6.28)
f = frequency(60Hz)
L =being the inductance of the inductor you are using. (the primary side of a separate transformer)
sometimes it is good to have a transformer with multiple taps so you can tune the inductance (and therefore the amoutn of current) without having to undo many wires, and find another inductor or transformer.
hope i helped
Nick,
some3
Wed Mar 25 2009, 07:00PM
some3 Registered Member #1887 Joined: Sun Dec 28 2008, 02:19PM
I know this equation for inductive reactance.
But how many ohms do I need to limit the current of the HV transformer I know I have multiple taps but anyway.
Or do I simply need a coil of a transformer for 230V whit taps every few turns?
teslacoolguy
Wed Mar 25 2009, 07:09PM
It's as simple as ohm's law. find the reactance of the inductor you are using at the frequency you are using it at and then use I=E/R to calculate how much current will pass.
