  • Guests: 73
Banana Man (41)
TheAnomaly (13)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
mercury substitute?
Backyard Skunkworks
Mon Feb 23 2009, 07:12PM
I've never worked with galinstan, but my chemistry instincts tell me that polyfluorocarbons would not wet. So I'd test it on some Teflon.
aonomus
Mon Feb 23 2009, 09:13PM
Just to put it in perspective, NaK pretty much *explodes* with any moisture or free protons.... Even though ammonia doesn't have a free proton, it was never stated as anhydrous or a solution in a different solvent....
We can probably help you better if you describe the process that you are trying to do, there may be alternatives that don't require a liquid metal.
AndrewM
Tue Feb 24 2009, 07:09AM
I certainly don't require a metal, but my density requirement makes a liquid metal an obvious choice. I have a gas nozzle in the bottom of a vessel which needs to be isolated from the contents of the vessel while still being able to deliver gas. Whatever I choose, its gotta sink to the bottom of the vessel and not dissolve or react with the contents.
Also my first post says the ammonia would be aqueous, so I've already discounted NaK
Sorry for being coy, you know how it is when you're not working alone. ::sigh::
Bored Chemist
Tue Feb 24 2009, 06:11PM
I seem to have been overdosing on the stupid pills. I thought that you needed a liquid metal for conduction of electricity or heat.
If all you need is something dull and dense then you could try the "fomblin" range of oils or the "Fluorinert" oils.
The problem with these is that you might want to sit down and take a deep breath before looking at the prices.
Vegemeister
Mon Mar 16 2009, 09:02AM
Vegemeister Registered Member #2027 Joined: Mon Mar 16 2009, 07:34AM
Try a perchlorinated parrafin. Fluorinated ones work too, but they're hidiously expensive, and much harder to synthesize yourself. If you, like everyone and their brother these days, are operating a chlorate cell, Get some PVC and put one of these around your anode.
_______
|    ====(hose)
|  ------(wire)
:  A  :
:  N  :
:  O  :  <= Fiberglass cloth, terra cotta, pvc with holes angled outward down, etc.
:  D  :     (Could be solid, but conductivity is better with something porous)
:  E  :
Lead the chlorine through a water bubbler to get rid of the salt and a CaCl2 dryer for the water, then bubble into a beaker of mineral oil under strong sunlight (or a high power UV lamp if you have such a thing.)
Free Radical Halogenation
speakerguy79
Fri Mar 20 2009, 05:14AM
speakerguy79 Registered Member #1460 Joined: Thu May 01 2008, 12:45AM
How dense is Flourinert?
Bored Chemist
Fri Mar 20 2009, 06:57AM
Fluorinert.
about 1.8 g/ml.
speakerguy79
Tue Mar 24 2009, 05:20PM
So would flourinert work? It's not cheap but you can get a gallon of the stuff for what a tiny amount of a Gallium eutectic would cost you.
