  • Guests: 58
My First SMALL DRSSTC (Now with 4X Secondary Length Performance)
first  3 4 5 6
StevenCaton
Wed Jul 08 2009, 05:01AM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
Ahhhhhh yes, adding toroids. I remember stacking up toroids on a spark gap coil I built once, just watching the sparks grow as I added more. Apparently DRSSTC's just love fat toploads. As far as I know, a spark over four times the secondary length might be a record.
Phillip Slawinski
Wed Jul 08 2009, 05:17AM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
SteveC wrote ...
Heh, well the small toroid doesn't change the tune point very much at all. It's there for field control only, so I can lift the major toroid farther from the strike rail.
Steve Conner got very close to 5X secondary length with his small coil. Link2
Also Steve Ward has achieved 4X.
StevenCaton
Wed Jul 08 2009, 05:21AM
So what brought about the major change in spark length. Did you drop the seconday down an inch, or are you just pushing the bridge more?
Phillip Slawinski
Wed Jul 08 2009, 05:33AM
SteveC wrote ...
I have the coil better tuned, I'm running a higher bus voltage (250V DC) and I've upped the primary current limiter.
Coronafix
Wed Jul 08 2009, 09:03AM
Great work Phil, it looks like a real gem.
Wed Jul 08 2009, 06:00PM
Phillip Slawinski wrote ...
3699342131 472982802f M 3700155178 D71b2de224 M
Sweet! cheesey
What's the box in the background of the left hand pic, is that the controller?
Phillip Slawinski
Wed Jul 08 2009, 06:08PM
Steve McConner wrote ...
Sweet! cheesey
The box in the corner is my VTTC, it's arcing to the aluminum front panel on it. Hard to keep that kind of thing from happening when the sparks are this long wink
Wed Jul 08 2009, 06:42PM
Big results from such little coil! Enjoy it!
first  3 4 5 6
