  • Guests: 62
Best to do with your tesla ground??
Duality
Mon Feb 02 2009, 03:06PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
What is the best i can do with my tesla's ground?
asking becouse i am ready so much about it that i don't know it anny more?
Alexandre
Mon Feb 02 2009, 05:31PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
I say what I used in my laboratory.
To land my coils and some experiments that require the equipment is grounded, then put in my yard around a 2.40M copper bar grounding, works very well for what I need...
Well, you should pound something thick and long into the ground, like a metal pipe or something. Then use something very low resistance that connects tesla coil to the spike. What i did with my sstc is put it on the mains earth ground(the third prong). But this could mess up other grounded things and do other bad things.
Duality
Mon Feb 02 2009, 06:53PM
i have broken two mosfet's by connecting secondary ground to main ground,
and connecting secondary ground to earth pin or common ground in house.
well ill try to hammer a thing (of course of a metal) in to the ground,
any idea how deep?
since i am just 2 meter's away from my backyard i maybe could do this.
one more thing my Tesla doesn't like to spark to my ground (of secondary) butt it does to my finger?
Shaun
Mon Feb 02 2009, 08:35PM
Are you sure the bad grounding was the reason your FETs died? Because in my experience small SSTCs can use mains ground without any issues.
If it is indeed a small coil, probably the best thing you could do would be to sit it on a metal table and connect the secondary ground to the table.
Duality
Tue Feb 03 2009, 01:33PM
i have the sstc running with a ne555 at the moment (i hope to make a better driver soon) butt when f I get near my ic to adjust my frequency the spark goes harder or become smaller,
why is this?
Wolfram
Tue Feb 03 2009, 02:01PM
Because you change the resonant frequency of the tesla coil secondary when you get near it, pulling it into or out of tune. This is why most people use feedback on SSTCs.
Anders M.
Duality
Tue Feb 03 2009, 02:47PM
this is my first tesla i am still learning how it works
i now how it works but i meant the circuit's ;)
oucivileng
Fri Feb 06 2009, 01:32PM
oucivileng Registered Member #1772 Joined: Tue Oct 21 2008, 05:23AM
I normally drive a piece of copper pipe into the ground but it's frozen right now so I think I'm gonna try grounding my secondary to the dumpster outside my apartment building.
Fri Feb 06 2009, 03:17PM
I always use two grounds for my larger coils. One RF ground four one meter long pipes in the ground. This RF ground is coupled via a HF pass to the mains ground. Yes I like to be sure of a good ground tongue
