  • Guests: 29
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Uzzors' Coolidge X-ray Machine
first  3 4 5 6
Tue May 12 2009, 09:12PM
I haven't tried exposing a photoboard, but see no reason why it would not work as you suggest.
Evenness of illumination would perhaps be a practical problem. with the smaller tubes most often used by amateurs.
Having etched an X-ray image onto the board, one might then print from it like a lithograph! smile
Chris Russell
Thu May 14 2009, 09:23PM
Chris Russell ... not Russel!
I just featured this project on the front page. Great work, Uzzors! I'm looking forward to seeing what's next.
Fri May 15 2009, 12:08AM
Eirik, you made the front page! Well done, lad! smile
Fri May 15 2009, 08:16PM
Cool, thanks Chris.
I'm still looking for lead, it seems to be less common these days due to everything becoming "green".
syntroniks
Fri May 15 2009, 08:56PM
syntroniks Registered Member #1530 Joined: Tue Jun 10 2008, 03:34PM
Unfortunately yes, try car batteries, it is easy enough to melt. Also, make sure to neutralize the acid. Sodium bicarbonate should work if it is done carefully, but someone on here may have experience with that.
Firefox
Fri May 15 2009, 09:23PM
I believe fishing weights and weights for hobbyist gravity-racer (pinewood derby) cars are still made out of lead. I don't know if you can get these in quantity, but it is worth a shot, I suppose. You could also talk to people in the medical profession to see if they throw out lead aprons or are replacing x-ray equipment/shielding (one can hope).
Leinad
Sat May 16 2009, 03:55AM
Leinad Registered Member #1930 Joined: Wed Jan 14 2009, 07:36PM
Another source for lead could be from diver's weight belts. That is of course if you can find them.
rp181
Sat May 16 2009, 02:52PM
How much lead do you need? Sometimes, if you go to tire shops that install tires, they have some. Ask if they have any lead weights (I think they are used in centring) you could have. Several people got buckets of lead.
Sun May 17 2009, 06:27PM
ADVARSEL!
Use 1mm - 3mm roofing lead which you can cut with tinman's snips.
Do not start heating big tubs of molten lead metal!
You have only one brain cell* and the one environment!
*Perhaps more at the moment, but not more after heating molten lead for a while!
c4r0
Wed May 20 2009, 01:59PM
c4r0 Registered Member #151 Joined: Sun Feb 12 2006, 02:53PM
Check this out guys amazed
first  3 4 5 6
