  • Guests: 59
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
sstc + audio modulation
Wed Feb 11 2009, 04:33PM
Robert2 wrote ...
Ok i use only one 555 with out interupter. Use 74hc14 ?
I'm sorry, of course you can use one extra 555 as an interrupter.
You can use a 74hc14 based self oscillator to tune up to resonant frequency.
You can also use the PLL topology: Link2
LithiumLord
Wed Feb 11 2009, 05:43PM
Well, in fact that 555 version is pretty bad as it uses a pretty scary modulation mode. Instead in case you want an actual open-loop PWM I'd stick to any avalable PWM controller (starting with the good old 494 and carrying on with the new TI chips). If you'd prefer feedback, you can still implement the PWM by making an RC delay circuit after the input trigger. Picked up with a comparator and then combined with the oroginal signal via an AND gate this gives a perfect deadtime via delaying the rising slope (the AND gate makes the falling one remain intact). Using two of those circuits for direct and inverted signals while applying a normalized modulation signal to the comparator negative pin will result in a variable threshold and, therefore, a voltage-controlled PWM.
Robert2
Fri Feb 13 2009, 09:42AM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Link2 look this circuit, i give only audio in B bc107, without interupter, i make jumper swith. 555+audio no good work :P
Robert2
Wed Mar 04 2009, 06:55PM
1st test of modulation
Old movie with first light
And new with 1/2 power input
It's all I make 2th sstc- plasmasonic
