  • Guests: 56
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
High Voltage Diode
MRacerxdl
Fri Jan 09 2009, 03:53PM
You can get UF400X Series, that are ultrafast and are not much expesive, I used before a UF5408 on a 100Khz SMPS, and it worked fine, and the voltage drop still at 0,6V.
The 9V Batery is 2500mAh so short current is more than 2,5A.
Fri Jan 09 2009, 04:50PM
Yes, as the Mestre says, you can find the fast version of the famous 1N4007 - the UF4007 - at about ten for an American dollar on ebay. Strings of those should work well.
Wolfram
Sun Jan 11 2009, 03:02AM
Mestre Racerxdl wrote ...
Normal MN1604 9V batteries do certainly not have a capacity of 2500mAh. Here Link2 is the datasheet of a standard 9V alkaline, with a stated capacity of 600mAh if you draw 25mA from it, less if you draw more.
Anders M.
