  • Guests: 43
Mathias (42)
slash128v6 (53)
01/31 Mathias (42)
01/31 slash128v6 (53)
02/01 Barry (71)
a different breed of tesla coil
teravolt
Thu Mar 30 2006, 06:03AM Print
In my last thread I am asking about the series capasitance for a reson witch may have applications about the circuit I am working on and I am interested in what the forum thinks. My current circuit that I built is a little different in its construction and the same in principal. The controle part of it has a master oscillator, an interuptor, and a bridge ON time width adjustment. To create my bridge controle signal the master 555 generator is chopped with the intineruptor (555) that has a width adjusment (74HC4538) of its own. They syncronised together with a D-type flip-flop (74HC74) and a AND (74HC08) gate curtisy of Steve ward's circuit with the 74109 I believe. This then goes into a divide by 2 (74HC74) to create my A and B signal. A & B are then put into a one-shot (74hc4538) to controle the width of A & B. To this point all our SSTC are the same. I Am shure that the next part of my circuit has been thought of and that is this. Each quarter of the H-bridge is isolated eleticaly buy using optoisolators and 4 indipendant power supplies insted of transformers and transformer driver circuits. A and B TTL go into mic4427 drivers to drive the LED portion of the opto. The output of the opto (HCPL2630) is inverted and level shifted (MIC4426) from 5 to 15v. Each drive circuit has its own set of power supplies 5v, 15v, 20v and one 5v for the TTL. After A, B is shifted to 5v to 15v this drives a 14A (IXDD414CI) mosfet driver. I had the best results when I used 12 of the 8 pin dip version when I was using 12 igbt H-bridge and creating 6A's and 6B's. So now I am using 4 IXDD414CI to drive 4 40N60's for my bridge. Each has its own transorb and blocking diode rurg80100 hyper fred. The output of my H-bridge goes to a series RESONANT primary tank of 7-5 turns that exsites a 14" secondary of around 250KHz.
I apoligise for the oral description and no shematic. I am working to lern psice to generate schematics and pictures. Any how the point of this exersise for me is to eliminate the cupling transformers and its associated parts. I intend to try Cprim. as a cupling and resonant. As a test bead want to see how efficiant I can get it and see if frequency and modulation controles spark length and shape. I also plan at some point to recofigure it as a DRSSTC. Right now I am blowing fets with the new configuration and I need to scope out the new setup and sweep it. stay tuned. N.B.
Thu Mar 30 2006, 10:06AM
I prefer gate drive transformers to optoisolators. They're simpler, cheaper, and have built-in protection against arm shoot-through. I also found it pretty hard to understand what your post was trying to say sad
Dr. Shark
Fri Mar 31 2006, 10:30AM
I apologize for my previous post (now deleted). I know a lot of smart people with dyslexia, so until I know better I will assume you are.
I can see some advantages not using transformer coupling, e.g. you can have a negative bias on the IGBTs during the interruptors off period. But unless you are very good with electronics (your generous use of level shifters and flip-flops actually suggests you are...), I think the added trouble of building the additional circuitry would not be worth it.
Dr. Drone
Fri Mar 31 2006, 06:14PM
shades
GimpyJoe
Fri Mar 31 2006, 07:23PM
suprised wow! Did the brick actually blow apart or are those just big cracks? I bet that was interesting.
Dr. Drone
Fri Mar 31 2006, 07:28PM
shades
williamn
Fri Mar 31 2006, 08:07PM
williamn Registered Member #55 Joined: Thu Feb 09 2006, 04:56AM
On drive transformers vs opt isolators, only issue I had on my drive transformers was I had a flash over on my 10kva DRSSTC and the inductive kick on the transformers took out everything behind them. The kickback was so bad it blew my TVS’s and Zeners right out of the board, ugggggg. Even the OCD feedback CT blew the bridge behind it.
I had the exact same thing happen, I even lost all of my 5V logic ICs.
teravolt
Fri Mar 31 2006, 09:01PM
Sorry about the wordy description and I am rushing to make a scematic. I know it looks like I went over the deep end but I wanted to try something different. There is nothing wrong with transformers and even Glassmen power supply's H-bridges are diven with transformers. With mosfet drivers that are opticaly isolated I can drive the H-bridge mosfets much harder and directly and faster to turn them on inside 100ns. this has the advantage of higher frequencys. maby the elusive 10Mhz coil. Ask questions. thanks N.B.
teravolt
Tue Apr 04 2006, 04:46AM
hear are a cupple of picturs
1144125997 195 FT6114 P4
Dr. Shark
Tue Apr 04 2006, 09:36AM
Very nice! Would you care to provide a closeup of the driver electronics?
