  • Guests: 37
09/29 Ultra7 (55)
09/29 uitvinderalex (37)
09/30 Terrorhertz (16)
Post Your Cool Pic Here!
Experimentonomen
Sun Mar 16 2008, 10:45PM
I want to see schematic.
Mon Mar 17 2008, 06:40AM
Ok i drew a quick schematic
phasing of primary is important
core must have ~0.5-1mm air gap
i dont have time now so ill answer any questions later
1205736035 152 FT6000 Sg3525
EDIT
Some more things:
set frequency to ~20-21kHz
duty cycle adjusts output power
Mates
Mon Mar 17 2008, 11:12PM
Plasmaddict wrote ...
130KV from single flyback
(assuming 1KV/mm air dielectric strength) smile
Hey Jan, 15cm = 102KV ! (using 1,27cm square rods). You have barely 90KV (I would say below 80KV according the sharp endings of your electrodes)... But it's nice.
Once I had a fly-back form a TV which could make also like 13cm sparks but this one was exceptional and it died after a while anyway. I think you are at the very edge and most likely you destroy it...
CT2
Tue Mar 18 2008, 05:05AM
The other night I was kind of bored and was playing around in photoshop with one of my tesla coil pictures. After a little bit I managed to get this cool effect on all the sparks showering off the topload, to get the full effect and detail you have to full screen it. This is the original beside the photoshopped copy:
1200251661 180 FT37370 Dsc 0125 Th
(for some reason I can't upload pictures right now? so I have to link it)
Tue Mar 18 2008, 06:08AM
My poor-man's flash trigger. I extended the leads on the reed switch and made a pressure sensitive switch under the container of water.
1205820865 53 FT1630 Splash
Tue Mar 18 2008, 03:16PM
Mates wrote ...
hey, do you have any spark size vs. voltage graph, for different electrode shapes? I was searching for one for quite some time.
Experimentonomen
Tue Mar 18 2008, 04:18PM
Sheesh CT2 that right pic look creepy.
Mates
Tue Mar 18 2008, 07:23PM
for rod electrodes
Wed Mar 19 2008, 06:28AM
Same idea as before but I set up a more sensitive trigger for the flash (still pressure sensitive).
1205908078 53 FT6000 Splash2
1205908078 53 FT6000 Splash3
1205908078 53 FT6000 Splash4
Wed Mar 19 2008, 08:07PM
That looks quite cool Nik.
