  • Guests: 36
mcsnwv (38)
fatboyslim (33)
09/29 Ultra7 (55)
09/29 uitvinderalex (37)
09/30 Terrorhertz (16)
Post Your Cool Pic Here!
robert1
Thu Mar 06 2008, 07:46PM
robert1 Registered Member #686 Joined: Sun May 06 2007, 09:22PM
For the Meters, its a bit of collecting them as well (at least for the Philips Nixie-Tube one (i have another 3.5digit in my other home).
However, i do put them to use every now and then, although im mostly using the other ones (which feature a HPIB port, which is very usevul and also have a very good TRMS converter thats useable up to 1Mhz).
Mates
Tue Mar 11 2008, 07:25AM
An angel (the head is made in photoshop wink )
1205220315 1025 FT6000 Angel
Bennem
Wed Mar 12 2008, 09:32PM
Here's a couple of videos of my last DRSSTC
taken at a 2008 Nottingham Teslathon.
and this one was its last run, an arc blows half of my full H-bridge of IGBT's... sad
cheers,
Mel.
Dr. Drone
Thu Mar 13 2008, 05:05AM
shades
LarsE
Thu Mar 13 2008, 12:46PM
LarsE Registered Member #153 Joined: Sun Feb 12 2006, 03:44PM
Testing my ETG. cheesey
1205412346 153 FT6000 Flash
Bauerb2
Fri Mar 14 2008, 03:07AM
Bauerb2 Registered Member #973 Joined: Tue Aug 28 2007, 07:32PM
One of the cars i've been working on. Plymouth Prowler. Modeled in 3ds max 9, rendered with vray cheesey
1205463828 973 FT6000 26
1205463828 973 FT6000 28wow
more pictures here Link2
Sat Mar 15 2008, 04:23PM
130KV from single flyback
(assuming 1KV/mm air dielectric strength) smile
1205598194 152 FT6000 130kv
Sat Mar 15 2008, 07:04PM
Nice one, Jan! amazed How did you do it? And shouldn't that flyback be immersed in oil?
Sat Mar 15 2008, 07:39PM
Uzzors wrote ...
I see no reason for immersing it in oil, it is doing fine in free air smile The only problem is that everything gets charged up by static electricity, including me (I can even feel my hair move a bit and the clothes stick to my skin), this can be a shocking experience... And of course it makes LOADS of ozone and corona wind cheesey
Driver is the original flyback topology with a resonant capacitor.
Sun Mar 16 2008, 10:20PM
I've always wondered about your flyback driver Jan, does it operate like class E? Could you post the drain waveform?
