  • Guests: 69
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
Post Your Cool Pic Here!
Sun Sept 30 2007, 04:44AM
The launch is rapidly approaching (2 weeks), so it was time to put some paint on Krazed.
Of course, you can't launch the GPS tracker with any old paint job, so it was time to break out the System.
We discovered that if you use run of the mill spray paint, spray it on, wait 5 minutes, then spray it with florscent paint, the florscent paint will craze over and form a 'desert playa' patches, the size of which are dependent on how heavy you put on the top coat. I light coat gives a very fine pattern, with features about 1/4" in diameter, a heave coat gives the result you see in the pics.
This time we were armed, and did a few trials to to see what color effects were possible. Notable ones included green/black, yellow/red, red/black, and red/bue.
1191126521 56 FT6000 Img 2892 1191126723 56 FT6000 Img 2893
1191126810 56 FT6000 Img 2899 1191126920 56 FT6000 Img 2867
So we decided on the red/blue, but the red looked kinda pink, and was to bright, so we put a coat of blue clear on it, and covered it with a coat of clear. So there here he is:
1191127018 56 FT6000 Img 2884 1191127189 56 FT6000 Img 2890 [
Sun Sept 30 2007, 11:00AM
Nik wrote ...
I knew it was the frequency of the arc flipping on and off, I meant the smaller point of contact VS the larger ones.
I notice this even with my flyback driver that runs at several 10's of kHz, I think it has to do with the surface of the electrodes that the arc doesn't move continuously on them but rather jumps little "steps" because the surface of the ladder is never perfectly even.
Sun Sept 30 2007, 12:45PM
Yay, crazed paint job for a krazed rocket! That looks great, I'm tempted to try it on the pickguard of my old guitar.
Simon
Wed Oct 03 2007, 12:22AM
One reason why circuits are smaller these days:
(An old op amp)
1191370722 32 FT1630 Opamppicsmall1
1191370722 32 FT1630 Opamppicsmall2
The insides:
1191370722 32 FT1630 Opamppicsmall3
1191370722 32 FT1630 Opamppicsmall4
Hazmatt_(The Underdog)
Wed Oct 03 2007, 06:12AM
talking about rockets... did you guys see the X-wing fighter with 4 engines in it? its supposed to launch on the 10th but i dunno what the link is.
That's a crazy rocket.
Wed Oct 03 2007, 02:21PM
Yes I have head plenty about it wink
here is the build thread
Electroholic
Tue Oct 09 2007, 01:03AM
ragnar
Tue Oct 09 2007, 03:11AM
I was worrying about that -- and the flight dynamics (of lackthereof) of what was designed to look cool as science fiction, as opposed to flying... =P
I guess it would have worked great in space! =-D
Tue Oct 09 2007, 04:03AM
They are still speculating on why exactly it died--it should have worked--the most plausible one I have heard was that the launch rod was to short, which caused it to take off at an angle, which overstressed the 'fins' and lead to the catastrophic failure.
It did make a nice picture though!
1191902534 56 FT6000 Xwing
taken from here Hopefully no one will come and kill me for rotaing/croping it.
Tue Oct 09 2007, 06:50AM
I hope this next time they actually stop a moment and figure out its C.O.M. and balance it properly. That and actually build a decent superstructure.
