  • Guests: 57
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Post Your Cool Pic Here!
Wed Aug 08 2007, 04:01PM
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
It's pretty obvious to me....your attempt to make a peanut butter and jelly sandwich somehow took a turn towards copper clad and a digital camera....
What's my prize?
..also...where does the "freakin' laser beam" go?
-Doug
Wed Aug 08 2007, 04:51PM
Are the traces mirror-reversed / wrong side exposed?
Capper
Wed Aug 08 2007, 04:58PM
Capper Registered Member #914 Joined: Fri Jul 20 2007, 06:22PM
You etched a negative of your ground plane.
Wed Aug 08 2007, 05:40PM
Hey, very cool pics everyone. Is that fusor completely under glass envnelope?
Peter: Does your printer have a ''B & W Halftones'' setting or something similar under quality/toner save setting? Some modes may have it set automatically.
It needed to be set to none/solid otherwise printer messes up the black/white boundaries (obviously bad) and mine also tended to randomly shrink the entire picture for a part of millimeter, enough to cause the infamous top/bottom side mismatch after printing.
When properly set it printed very precisely.
Wed Aug 08 2007, 06:05PM
Sulaiman got it, I mirrored the wrong side of the board sad
My printer is configured correctly, it is just a really cheap printer ($300 for a full color laser, including a full set of 'full' 5k page toner cartridges). It feeds the paper at a somewhat random speed, so everything gets stretched/shrunk a few percent at random. Not a problem for normal things, but when you are trying to get the top/bottom to line up to +/- 0.002" it gets to be a major pain.
Capper
Wed Aug 08 2007, 06:12PM
Marko wrote ...
The fusor grids are under a pyrex bell-jar sandwiched between aluminum sheets. I'll post a picture of the whole assembly after I get home later today. There are some more photos here:
Fusor Link
Reaching
Wed Aug 08 2007, 06:50PM
whats about the x-ray emission? I asked the german wikipedia for answers about the fusor.
The x-ray emission is the main radiologic risk. and i dont see any grid to screen the x-rays
Do you use deuterium or so? What psi and voltage on the electrodes.
A bit more info please :)
Hazmatt_(The Underdog)
Wed Aug 08 2007, 07:52PM
well... whatever the case is with your board ... , your connection pads either need to be bigger or the drill hole smaller because mechanical movement will tear them off of the board.
And you need to rethink how you're etching these boards. If you're going to be etching something this sensitive you're going to have to agitate the board or else you will get what you see there, a board that is over etched and under etched.
I have had that problem too from leaving boards in solution, no agitation, solution too cold, or trying to re-use an old solution.
If I had to etch your board I would agitate it in my FeCl3 tank while hot.
Capper
Reaching wrote ...
I don't run the voltage high enough to get x-rays (I'm only running about 450 VDC), and I'm not using any deuterium - so It's not a real fusor making radiation - it's only a "demo fusor" making plasma from trace gas. The guys using deuterium and producing neutrons have stainless steel vacuum chambers and much better vacuum pumps (I can only get down to about 100 microns). If you want to learn more, there's a fusor forum at: Fusor Forum
Scott
Wed Aug 08 2007, 11:25PM
The etching on the board went fine, it was the transfer that was foobared. I was using PNP transfers, which just don't work for large boards with lots of .008" traces (especially when using uber thick copper). I don't have the pre-etch pics handy (but you can see where I reworked the transfer in the pic of the board etching, black = done by marker), but about a third of the traces were screwed up after the transfer, so I tried to clean them up, but that obviously didn't work to well. The holes for the connectors were the right size, but the library was drawn assuming plated through holes, so the pads were way smaller than they should have been for a homebrew board.
But none of that matters now, I have decided that for the $30 (incl s&h) it will cost to have the board made at batchpcb, it just isn't worth my time. And now I get a solder mask and silk smile
