  • Guests: 67
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Post Your Cool Pic Here!
kv
Fri Jul 20 2007, 03:16AM
kv Registered Member #809 Joined: Wed May 30 2007, 08:59AM
cool!!!, is the big box down the bottom the cap?
Hazmatt_(The Underdog)
Fri Jul 20 2007, 03:45AM
yea that's the pulse cap. 450 pulses/second max. I'm going to need a big switch for it though, so I have to think about how to achieve that goal.
Fri Jul 20 2007, 08:56AM
Well, it would make a great DRSSTC tank capacitor... :P
Fri Jul 20 2007, 06:44PM
but where would I get a switch capable of 18KV? I dunno what the current from that thing would be, it has to be horrendous. I'd probably have to go with a rotary unless I can find a SF6 switch capable of switching 20J somewhere.
kv
Fri Jul 20 2007, 10:27PM
how are you going to charge this thing????
Fri Jul 20 2007, 10:53PM
110nF is quite low for DRSSTC's, except maybe smallest ones, while 18kV is quite high voltage. (It would look silly in a coil size of mjolnir).
It may work in longer bursts, although everybody seems to consider high characteristic impedance less efficient.
Depending on it's voltage reversal rating, you may actually be much better to use it for a SGTC.
If it can handle such operation and be efficient, you can use two outer terminals for a killer 36kV 27.5nF capacitor. Good for like 20kV at 4kW, maybe even more depending on it's reversal rating.
Do you have any information on internal constrction of that cap? What dielectric does it use?
Sat Jul 21 2007, 12:02AM
Fffffrying tonight.. We're cooking GOOD!!!
lol :)
(btw those things *really* HURT!)
-A
1184976164 96 FT6000 Electricchair
Sat Jul 21 2007, 01:00AM
They don't specify the dielectric, but it is a pulse cap and the make is BYCAP INC. 2x .055uF 18kvdc 450pps max. That's all I know.
Chris
Sat Jul 21 2007, 02:35AM
Chris Registered Member #8 Joined: Thu Feb 02 2006, 04:34AM
My latest chemistry toy, just tested today. It's a two-stage quasi-continuous reflux distillation aparattus, all borosilicate, teflon, corrosive rated stainless pressure/vacuum gauges, and fluorosilicone based stopcock grease.
1184985338 8 FT6000 Hpim1357
Sat Jul 21 2007, 03:50AM
Sweet setup you have there. The only trouble with second hand labware, and I have a lot too, is you don't know what has been in it, so you don't know how clean it is. This can be real problematic depending on what you want to do. Flushing with Nitric would probably be a good idea, and BC would probably have some suggestions too.
Chromic-Sulphuric used to be used a lot, but the Cr 6+ is a pain to dispose of properly.
