  • Guests: 33
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Post Your Cool Pic Here!
ragnar
Sun Apr 01 2007, 11:39PM
Great Scott, that is impressive.
Big pulse capacitor?
Mon Apr 02 2007, 08:54AM
Scott Fusare Registered Member #531 Joined: Sat Feb 17 2007, 10:51AM
I am using a pair of 230 μF 7kV pulse caps wired in parallel. This is close to what the original (Russian) researchers used.
Chris – I do intend to try out different salts as colorants. The brilliance of the initial flash, and to some extent the fireball, tends to saturate both eyes and camera so some experimentation will be required.
Tue Apr 03 2007, 07:58PM
Daniel Uhrenholt Registered Member #125 Joined: Fri Feb 10 2006, 01:52PM
Guess what this is confused
1175630093 125 FT6000 Img 1251
I can tell you that it`s something I work with every day cheesey
Sparking all the time, Daniel
Tonic
Tue Apr 03 2007, 09:02PM
I'll take a shot - is this a plasma cutter?
Wed Apr 04 2007, 01:53PM
nope cheesey It`s a ED wire-cutting machine.
It is also called EDM (Electric Discharge Machine) cutting.
The machines I work with is extremely accurate, they are used for high precision workpieces in the tooling industry. They make a very fine surface on the iron, cobber, brass, graphite or tungsten or whatever we cut in.
It`s a great tool to have if you need to cut some tungsten electrodes cheesey
Daniel
Ken M.
Wed Apr 04 2007, 02:10PM
confused but isn't a an electric discharge from a TC or Flyback or MOT Plasma just so long as it gets hot enough?
Wed Apr 04 2007, 02:32PM
Hi HVAC Plz.
This machine don`t use high voltage, but high current pulses. The machine i work with has 8 Class D amplifiers, that generates up to 700A pulses through a capacitor circuit.
Here is a link to a explanation:
Cheers, Daniel
Ken M.
Wed Apr 04 2007, 09:48PM
OHHH ok, i was just thinking that they were simmilar, with the energy and power used. but thanks for the link and clarified explanation!
Fri Apr 06 2007, 07:21PM
Ok, but there must be a pilot HV transformer wich starts up the arc?
And what class D amps have to do with it?
Fri Apr 06 2007, 09:02PM
Hi Firkragg
This is what I learned a few weeks ago about the machine:
There are no transformers in the machine, it’s all Solid State. There is a big switch mode power supply in it. The old ones are based on Class A amplifiers, and they have a BIG transformer in them (in our case 3phase) they are from the 80ies cheesey
The Class D amplifiers make the high current frequency (or what I call pulses) that moves material from the work piece. There is a “spark gap” between the thread and the work piece, it’s about 0.2-0.05mm, but the gab depends on the power setting on the machine.
I need some pictures from a book from work, if you want to know how it starts the spark…
When a spark flies from the thread to the work piece, some material are vaporized and moved from the work piece. This happens many times per second, it’s not a fast way to make things in metal, but it’s one of the most precise.
It can “feel” how close the thread is from the work piece, and then it will back off if it’s too close, and release a pulse. I don’t quite understand how it can do this, but it can confused
Because sparks develop lots of heat, it’s all under distillated water with “dielectric powder” (I don’t know the English word for it), and an insane water filter system that keeps the water clean.
And a big cooling system, the work piece must have a temperature about 20degrees celsius, or else the machine will shut down. This automatic shutdown happens because if it gets warm, the metal will expand and then we can’t hold the tolerances…
I don’t have any pictures of the On and Off time and duty cycle of the machine, but I can get it next week.
I will copy some of the pictures from my theory book and post them if you like. Or maybe measure some myself with my scope and differential probe.
Cheers, Daniel
BTW, the 700Amps are the peak current.
