  • Guests: 43
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Post Your Cool Pic Here!
Robert2
Thu Jan 24 2013, 08:10AM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
New DRSSTC is coming shades
1359015007 1773 FT6000 M4
1359015007 1773 FT6000 Avago
1359015007 1773 FT6000 M2
Hon1nbo
Mon Jan 28 2013, 12:23PM
My new RAM Disk benchmarks.... for the fastest game load times ever hehe.
1359375725 902 FT6000 Benchmark
I used to use a program called "RAMDisk" by DataRAM, which worked great until I installed new RAM to max out my motherboard at 64GB. Then it crashed for some reason, so I've been using IMDisk VDD with manual saving to HDD until I fix it.
-Jimmy
Adam Munich
Wed Jan 30 2013, 06:18AM
We had a casualty frown
Turns out these things are filled with 'caplets' and an oil that smells like pine-sol.
1359526662 2893 FT6000 Dsc00389
I imagine the caplets are still usable; and probably well suited for resonant work being oil cooled and all.
Hon1nbo
Wed Jan 30 2013, 02:34PM
Came across this while cleaning out a parts shelf. Last Spring I got bored between two classes which were separated by 45 minutes, so I put together a coilgun out of parts I had lying around (coil not found when I dug this up):
1359556474 902 FT6000 30 Minute Coilgun Copy
-Jimmy
Josh Campbell
Wed Jan 30 2013, 04:48PM
Josh Campbell Registered Member #5258 Joined: Sun Jun 10 2012, 10:15PM
DaJJHman wrote ...
-Jimmy
Disposable camera flash circuit dumped into a small coil. :D
Adam Munich
Thu Feb 28 2013, 04:07PM
The wires in my wall are hot ๏_๏
10h51m28s230
flannelhead
Wed Mar 27 2013, 02:53PM
Hi there!
I haven't been too much into high voltage lately, but I recently found an old secondary wound around a film canister. I threw together a simple driver from scrap parts, and much to my surprise, it worked!
1364395648 952 FT6000 Tessjpg
This thing is powered by a 12V/300mA wall wart. The driver is simply 74HC14 -> BS170 (level shift to 12V) -> 2N3904/06 totem -> IRFP240. There's also a 555 timer which is interrupting the signal. Break rate is currently 2 Hz as I don't believe the little wall wart could survive much more. F_res is about 5 MHz. Antenna feedback is not too reliable, I might try PLL next. It occurs to me this one could also benefit from a boost converter charging a capacitor to a little higher voltage and discharging it to the primary... We'll see, this could become quite nice a nano coil.
Ben Solon
Tue Apr 02 2013, 12:53AM
1364862517 3900 FT6000 Img 0126 1364862816 3900 FT6000 Img 0131
1364862817 3900 FT6000 Img 0150 1364862818 3900 FT6000 Img 0136
My Easter weekend was a bit of fun shades
This was what my half bridge smps turned into in a real hurry. It's running off of 28v @ 5.6A, I don't think it'll handle mains simply because of inadequate gate drive(don't try switching 300nC gates with 350mA gate drivers unless you like the looks of natural logs). Three stacked gate drive chips still aren't enough to charge all 12v across the gate during the entire half cycle, so i'm waiting on the 3A ones coming in the mail.
Robert2
Fri May 31 2013, 02:39PM
942169 471498232929213 649889857 N
574568 471498196262550 1248890819 N
426596 471498212929215 29611796 N
263357 471498219595881 592967210 N
TRX 708 :) My new little x-ray staff
Sun Jun 09 2013, 07:49PM
You've GOT to be joking.
I have a recycled sign similar to that on my shed, to keep tea leaves away.
-A
