  • Guests: 29
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Post Your Cool Pic Here!
dmg
Tue Sept 28 2010, 05:15AM
Hmm.. the isolation's rating is quite high, but with only 20VDC flowing through these capacitors, and these SCRs switching around the same. probably more of a worry at higher voltages?
also, I posted far earlier in this thread, I killed one of these bricks before, pushing thier very limit, and upon disection I discovered the nice white insulation between the die and sink.
that and electrical tests show no connection from plate to any terminals.
Edit: Here it is! Link2
Avalanche
Sat Oct 02 2010, 04:37PM
fuzz farce, sparked off by using my recent valve amp project as a guitar amp and needing something to generate overdrive!
1286037370 103 FT6000 Img 5277 Cr Large
1286037370 103 FT6000 Img 5269 Cr Large
Dr. Drone
Wed Oct 06 2010, 12:17AM
shades
Wed Oct 06 2010, 12:53PM
Enjoying the last few weekends before winter sets in
DSC 0079
Killa-X
Thu Oct 07 2010, 10:38PM
Thats one heck of a view Dalus!
1286491105 1643 FT6000 Motters
What to do with 4 new mots... :D
Some other pictures of my dog, sky, and some grass. Just random test pictures.
ThThTh
Nicko
Fri Oct 08 2010, 08:23PM
Killa-X wrote ...
Th
That looks like a pretty chunky GSP - they tend to be a *lot* lighter than that! (at least all of ours have)
1263157276 1334 FT6000 P1020208
Killa-X
Sat Oct 09 2010, 01:54AM
Well, They say you want the ribs visable, ours isnt, but is easily felt through the skin. The vet said she is just a TAD heavier than average. We don't do much hunting, just play. She still runs a TON when people walk by, running up and down the yard at full speed. I took this picture of her while standing on my deck 100ft away. using zoom :) Hunting for ground moles, she loves when they squeak when she jumps on them.
So you know, she's a German Shorthair Pointer.
ThTh
My finished SCR clamp. ~1650 pounds of force, 1200V 650A.
Ken M.
Sun Oct 10 2010, 07:38AM
Been meaning to try the macro and super macro function on my camera, so I figured I'd try on my new hand wound secondary
1286695384 618 FT0 Coil
1286695727 618 FT0 P1040014
1286695799 618 FT0 P1040015
1286695929 618 FT0 Smacro Forward Coil
Then while cleaning the brush disaster....
1286696024 618 FT0 P1040017
Hazmatt_(The Underdog)
Sun Oct 10 2010, 04:41PM
Nah, Just run your fingernail along the wire and straighten it out, then you'll need to learn how to use your palms to "twist" large sections of wire to take the slack out. It takes a couple of hours but that coil is salvagable. This also happens when it gets fairly cold outside and the form contracts. I've been through this many times, it's a pain, but you don't really have to start over.
Killa-X
Mon Oct 11 2010, 02:02AM
Went to Croton and Hardy dam on this nice sunny Sunday. Took fall pictures and happen to come across the high voltage fields at the dams. Just some random pics I thought I would share. More will be put into video later.
ThThTh
ThThTh
ThThTh
ThThTh
Th
Most the HV stuff was taken with 10-20X zoom.
