  • Guests: 54
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Post Your Cool Pic Here!
Electroholic
Wed Aug 18 2010, 03:26PM
Finn Hammer wrote ...
Electroholic wrote ...
I believe he is using the IGBT substrate as part of the waterblock by having it sit directly on top of the water channels, with the perimeter sealed by an o-ring.
No more wasting delta T on thermal junctions, just cold water on the back of the IGBT.
Edit:
I knew I've seen it somewhere
Jack, that´s close enough, just wondering now, how to deliver the cookie.
The word we wanted to hear is baffle. It is a baffle.
This baffle is embedded in an alluminum plate which forms the basis of the manifold.
The water enters the big rectangular holes on one side and have to pass the maze channels to exit the row of holes on the other side of the block.
The maze shape adds 2 features: first it creates resistance to the flow of the water, series resistance makes the flow equal in each channel.
It also forces turbulence to the flow, facilitating heat transfer to the liquid.
Third: The plastic insulates radiated heat from reaching cooling backplate made from alluminium.
Cheers, The Midget coilers of Denmark
Aww, I think I'm starting to see the genius behind this design now.
Running multiple parallel channels across the width of the device to minimize thermal gradient across the device. And you added baffles to equalize flow rate in different channels and create turbulence.
Not sure if I understand your 3rd point, tho, about the radiated heat.
Dr. Drone
Wed Aug 18 2010, 08:05PM
shades
Jrz126
Fri Aug 20 2010, 12:51AM
Jrz126 Registered Member #242 Joined: Thu Feb 23 2006, 11:37PM
My bricks... The big ones single igbts, and are good for 2500V, 1200A continuous. The little guys are 2500V 400A continuous. I have 3 more of each.
1282264734 242 FT6000 Img 3956
My SCRs. I cant remember the exact rating right now.
1282264920 242 FT6000 Img 3957
A gatedrive. Fiberoptic cmd/feedback. Undervoltage and out of sat protection.
1282265306 242 FT6000 Img 3959
dmg
Fri Aug 20 2010, 01:26AM
O_O
Fri Aug 20 2010, 11:47AM
0_o
*head explodes*
Fri Aug 20 2010, 06:25PM
Jrz126 wrote ...
Looks like a nice H-bridge in the making for a DRSSTC smile
Sun Aug 22 2010, 07:24PM
VTTC parts
1282505197 152 FT6000 1466
Robert2
Sun Aug 22 2010, 08:49PM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Hi!
70 1282509554 Thumb
61 1282509554 Thumb
80 1282508465 Thumb
My DRSSTC with 455nF, news photo with longer exposure time :)
dmg
Sun Aug 22 2010, 09:02PM
Dr. Kilovolt wrote ...
VTTC parts
Is that a spool of litz wire, kilovolt?
Sun Aug 22 2010, 09:33PM
Gatedbreakdown wrote ...
nope, it's a standard magnet wire but with thin cotton insulation on the outside tongue I got it for (almost) free so thats what I'm going to wind my secondary with. It may be too thin on the inside (ca. 0.35 mm) and get too hot, but we'll see smile
