  • Guests: 58
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Post Your Cool Pic Here!
Renesis
Thu May 06 2010, 06:02PM
Yesterday i found three IC's on a very, very old motherboard, with windows! Thats kinda neat, but im stumped as to what the purpose of this is? Was it used during fabrication, perhaps?
The one in the picture has 40 pins, and since it says INTEL '77 i suspect that this might be a processor. The other two are somewhat smaller, and has TI's logo printed on them.
Oh, and if any hobby photographers knows how to take good closeups with a cheap digital camera, without using a big magnifier glass, im all ears. This image was the best of 20. tongue
1273168612 2028 FT0 Pict1904
IntraWinding
Thu May 06 2010, 06:23PM
EPROM is Erasable Read Only Memory. It's non volatile (keeps its contents when the power goes off) but you can wipe it by exposing it to UV light and then reprogram it. Seems rather quaint now but it was quite cool at the time and you get to look at the chip too!
I think mainly you found it with just purely EPROM chips, but there where some CPU's that had inbuilt EPROM that were windowed too I think.
On the down side, the optical quality of the window is generally abismal, but you can still have some fun with a microscope.
Wiki Link2
Renesis
Thu May 06 2010, 07:25PM
IntraWinding wrote ...
Wiki Link2
I've always wondered how UV exposures were done in practice, shining through a normal IC sounds pretty intense. It makes more sense now, thank you. cheesey
I just wish i had my microscope here now.
Dr. Drone
Thu May 06 2010, 09:13PM
shades
Turkey9
Thu May 06 2010, 11:03PM
I collected four or five of those.... Along with an Intel processor that's DIP! about 40 pins like Dr. Spark mentioned. All of those chips i found had the windows covered by a sticker, did you're have that? I assume it was to prevent sunlight from wiping the chip smile
IntraWinding
Fri May 07 2010, 12:13AM
I think they were playing it safe with the stickers, to keep light out. I never heard of RF wiping before. Sounds like degaussing. EPROM's aren't that old by the way. I think the BIOS on my last PC (KT7-RAID) was on an EPROM - had a holographic sticker on it though to make look snazzy wink
Hon1nbo
Fri May 07 2010, 01:44AM
Renesis wrote ...
a lot of cameras, even cheap ones, tend to have a Macro mode of some kind, look for a mode with the picture of a flower, which is a common way of identifying it on most cameras I've seen that aren't high end.
Also, ignore using the zoom on the lens, it will send your focus range farther than the object, so if necessary rely on digital zoom which will drop your resolution but it will still be in focus.
-Jimmy
Renesis
Fri May 07 2010, 12:02PM
Turkey9 wrote ...
Yes, in fact they did. Removing it was a mere coincidence.
DaJJHman wrote ...
That seems to work, thank you.
MinorityCarrier
Fri May 07 2010, 10:35PM
I think the claim of erasing EPROMs with RF is bogus. The ex-INTELista I work with never heard of that being done, UV erasure was used. What's the mechanism for RF causing gate charge electrons on a floating EPROM gate to tunnel away? Why doesn't address line 'antenna effect' introduce charge?
A 10,000 pin socket part with a core dissipating 264 watts sounds untenable. A co-worker with a spouse still working at Intel hasn't heard of that, or about Intel Pathfinder Engineering working with that. What's the socket designation? Address size?
Just asking.
Fri May 07 2010, 11:36PM
MinorityCarrier wrote ...
I agree with you there. But can attest that there are 10,000 pin automatic chip testers (I just touched one). They go with robotic handlers to connect hundreds of chips for concurrent testing. Ever figure how many minutes of write, read, and erase cycles it takes to properly test a flash memory chip on the factory test floor?
