  • Guests: 41
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Post Your Cool Pic Here!
Electroholic
Sat Feb 14 2009, 07:00AM
Dr. Spark wrote ...
Just added a Softale to my collections of HDs.
The Rocker C, wild bike and check out the 240 Dunlap on the back!
The Softale has no visible back shocks and the 96ci motor is rigid mounted, so the engine as to be perfectly balanced and the reason Softale’s are a bit more $.
Off to start waxing and ordering accessories. Life is good!
Cheers,
Ch
1234580247 290 FT6000 Rocker1
1234580247 290 FT6000 Rocker2
Sweet looking bike!
BTW, is that a one way put on backward at the front?
Dr. Drone
Sat Feb 14 2009, 07:15AM
shades
Sat Feb 14 2009, 07:23AM
Wow, pictures do not do a justice for this amazing bike! I love the swing arm mounted fender and the fold out passenger seat! And stamping the HD logo on the tire? A nice little touch that is easy to overlook.
Hazmatt_(The Underdog)
Sat Feb 14 2009, 08:11AM
Watcha' need a floor mat for, a Harley that new don't drip oil yet! hahah.
Dr. Drone
Sat Feb 14 2009, 09:04AM
shades
Lakeowner
Mon Feb 16 2009, 09:44AM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
140nF 24kV tank capacitor is ready for fun :)
1234777435 1370 FT6000 Mittaus5
Electroholic
Mon Feb 16 2009, 10:42AM
Laakkonen wrote ...
seems like you are mixing caps, I see CDE caps at the bottom?
Diff in ESL/ESR might mess up current sharing.
Otherwise, very mean looking tank.
Mon Feb 16 2009, 02:38PM
Got pics of the new small 4.5 inch secondary. Not great looking, but good enough to work. About 14 coats (thick coats) of minwax clear coat quick drying polyurethane, similar to what Dr. Spark used for Fatboy (and i suppose all the rest of his coils, eh?).
Need the toroid, standoff/toroid holder, and the top cap.
Lakeowner
Mon Feb 16 2009, 02:54PM
Electroholic wrote ...
Yup there are 72x 942C20P15K-F's. FKP's ESR is a bit higher than 942C's, but not much. I connect terminals to the upper floor near FKP's and I hope that gives necessary milliohms. They are both so stiff caps that I think they will survive.
We'll see the failure or the operation :)
Kizmo
Wed Feb 18 2009, 06:04PM
After 3 explosion in row (10 dead mosfets) i finally got it right with CW-SSTC
Short specs: Steves minisstc, irfp460 half bridge, antenna feedback, running fullwave rectified and smoothened DC (2200µF capacitor)
Running 370VDC 100% CW
1234979966 599 FT6000 370vdc Cw Newbridge
Burning skin (yellowish salt streamers, whee)
1234979966 599 FT6000 Handspark
