  • Guests: 49
Proud Mary (62)
omegalabs (39)
Plasma Lover (32)
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
Post Your Cool Pic Here!
Wed Apr 23 2008, 05:34AM
electroholic gets it, but since I am out of cookies all you get are more pics :p
1208928751 56 FT6000 Filament
1208928773 56 FT6000 Flash
It has a ring of several filaments, about 10 all considered amazed
Wed Apr 23 2008, 08:40AM
This is the 32" DGM LCD I just resurrected by panel/controller swap :)
Didn't require much modification, a little work with an angle grinder on the bottom panel mount as the donor panel was 5mm bigger (grr!) and some self amalgamating tape on the delicate flexi-pcb's to prevent damage and shorting. I epoxied the control PCB in place on the metal frame as none of the mounting screws fit, and the two sub PCBs to the top of the frame. Had to also modify the metal display covers to not press on the glass, five minutes with cutters and a metal file took care of it.
Apart from a few black spots (this is best done in a clean room FWIW) it works just fine, and has increased its value by about $700 smile
If anyone else tries this, be aware that most panels are *not* electrically compatible. The AU Optronics panels are very similar to the LG ones, but may not work correctly unless the pinouts match and the controller is capable of recognising the commands. I did this to a 22" Samsung panel but the picture was noisy and washed out.
I've also done panel swaps on 17" LCD's, if the connector is the same with the power pins in the right place, the chance of it working is around 80%. Helpfully the backlights usually don't fit but that can be sorted out.
Interestingly, the old panel wasn't actually faulty but the controller's connector had been torn off the PCB somehow. This is a weak point in these monitors, resulting in strange display problems over time and eventually burning out the controller :( unless you have a good controller to swap this usually means its clusterfscked :(
-A
Tesladownunder
Wed Apr 23 2008, 12:35PM
I don't often contribute here but it ain't really science or electronics. Just 5 second shots of sparklers and a cordless drill.
Sometimes I get bored ....
TDU
1208954079 10 FT6000 Sparklerssmallcircle
1208954079 10 FT6000 Sparklersbigspiralcircle
1208954079 10 FT6000 Sparklersspirographcircle
1208954079 10 FT6000 Sparklersslinky
Dr. Drone
Thu Apr 24 2008, 05:09AM
shades
Fri Apr 25 2008, 01:49AM
Ice in april.
1209088196 53 FT6000 Crystals1
1209088196 53 FT6000 Crystals2
Bennem
Fri Apr 25 2008, 05:49AM
Any more pics or info on your new little half bridge?
Mel.
Dr. Drone
Sat Apr 26 2008, 02:19AM
shades
Bennem
Sat Apr 26 2008, 05:02AM
Hi Chris,
Thanks for posting the pics.....its looking great!!
as does all your work.
I'm always impressed with not only your coils function, but how each one
is a work of art!
I look forward to following it when you start your post.
Mel.
robert1
Tue Apr 29 2008, 07:52PM
robert1 Registered Member #686 Joined: Sun May 06 2007, 09:22PM
The least crappy photo from last weekend...
Heavily brightness/contrast enhanced because the crappy (HP) camera screws up badly outdoors
2008144408000002
Backyard Skunkworks
Tue Apr 29 2008, 08:37PM
1,700 Polygon 3D Skunkworks Skunk
Modeled in gMax
1209500604 1262 FT6000 3d Skunkworks
And then fully skinned...
3dskunkworksskinnedgr4
