  • Guests: 46
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
Discharging capacitor bank to subwoofer
Kizmo
Tue Dec 09 2008, 08:26PM Print
Hi!
It has been a while when i last time did something like this. I have few broken subwoofers (damaged cones) which cannot be repaired so they are perfect victims. This time i will use my electrolytics (18 x 3300µF/350VDC) connected in parallel resulting 59400µF @ 350VDC -> 3638J
I cant use any higher voltage because sub will most likely flash over internally. My goal is to get as much enery as possible driving cone out and get ultimate destruction! (speaker cone turned inside out flying across room...) cheesey
Has anyone else tried this? I will post some pics and vids when this is done.
Kizmo
Wed Dec 10 2008, 03:26AM
It was complete failure. 3.4kJ did just quite loud BOF sound but woofer is still in one piece and totally fine.
Need moar jiggawats
Wed Dec 10 2008, 03:52AM
Try seriesing the cap. You just need my di/dt 350v into a 4ohm load is only 30kw, 6kv into a 4r load is 9000kw probably more likely to do damage to the cone wink
Kizmo
Wed Dec 10 2008, 01:11PM
Link2 Stuff gets blown up. And that was not enough to wreck 10" pioneer :)
Maybe next railgun?
Berni
Wed Dec 10 2008, 05:30PM
Berni Registered Member #1132 Joined: Mon Nov 19 2007, 06:15PM
Wow a speaker survived that !?!
Id expect that many caps to blow the speaker to pecis across the room. Yeah it might be a good idea to try it in series to get more voltage and get a faster discharge.
Tom540
Wed Dec 10 2008, 08:06PM
Tom540 Banned on 3/17/2009.
Or try the discharge again but with reversed polarity. Maybe when you discharged it the voice coil slammed into the magnet maybe by reversing it you can get the voice coil to go the other direction.
KLH
Thu Dec 11 2008, 10:16PM
KLH Registered Member #1819 Joined: Thu Nov 20 2008, 04:05PM
I think the inductance of the speaker might be limiting the current. Also, subwoofers (the good ones) are built to withstand very high peak excursions.
I must say, MORE POWER = ASPLODED SPEAKER
