  • Guests: 65
09/19 raff (48)
09/20 PYLEMET-mk2 (36)
09/21 Bill G (65)
Bipolar gate driving
ben106
Tue Dec 09 2008, 11:23AM Print
ben106 Registered Member #1374 Joined: Tue Mar 04 2008, 04:14PM
Hi,
i've a question about bipolar gate driving (+12V=on, -12V=off). Does this work with a gate drive transformer ?
Maybe the real question is : does unipolar gate driving work with a GDT ? What does the gate see if I feed the GDT (1:1) with 0-12V ? I feel it will see +/-6V, so it's a bit too low to be reliable. Of course, one has to put a dc blocking cap before the GDT, so 0-12V is +/- 6V in reality.
What does experience say ?
Ben
Tue Dec 09 2008, 12:53PM
Experience says:
The average voltage across any inductor or transformer winding must be zero. If you try to force it otherwise, smoke will come out until it's equal to zero again.
ben106
Tue Dec 09 2008, 01:11PM
So, with a GDT you will for sure be driving the gate bipolar --> have to have +/- 12V at the outputs of the GDT.
Thanks a lot for the answer, now it's clear to me !
Tue Dec 09 2008, 04:17PM
Oh, and as a side note, for a gdt for typical smaller mosfets, you can use one gate driver ic, or a totem pole transistor pair and a 1:2:2 for half bridge, 1:2:2:2:2 for fullbridge and 1:2 for single switch(of course :P). But, if you don't want to have to wind all of that, or don't have enough space on your ferrite toroid or some other reason, you can use an inverting and non-inverting gate drivers, which will work in opposition, making a 24 volt peak to peak voltage across the primary. That will give the extra voltage you need to turn full on. An example would be ucc37322 and ucc37321 9 amp gate drivers, or tc4422, and tc4421(i believe that is it). You would hook inverting driver to one side of the gdt primary, and the non-inverting up to a dc blocking capacitor(i have used .39uf, Steve Wards mini sstc uses .1uf) and then to the other side of the primary of the gdt primary.
If you already knew this, i just typed that for nothing. Hehe..
LithiumLord
Tue Dec 09 2008, 05:44PM
I'd not try the single-driver concept. First, the drive current is twice higher, so if you want to pull each fet with 2 amps, the overall drive current will be 2 * 4 * 2 = 16A. Also you can't make a driver-side off-state of the bridge with only one driver IC.
Tue Dec 09 2008, 08:06PM
Ah, yea that might help alot to use two gate drivers :P. It really is not any harder to use two instead of one, and if made good can take up like 1 inch x 2 inches, or less. I and rather inexperienced(very may be a better word) and i made a pc board with the two drivers and it only takes up (goes to measure) 1 1/2 by 1/ 1/2. So, a one and a half inch square. Works well, small, looks alright, other than the solder joints. Best of all, EASY! CHEAP! Now i just need some F'ing 74hc14's and make a half bridge and i have a sstc.
jovica
Tue Dec 09 2008, 08:49PM
jovica Registered Member #1790 Joined: Fri Oct 31 2008, 10:10AM
Arcstarter wrote ...
Now I just need some F'ing 74hc14's and make a half bridge and i have a sstc.
I dont think 74hc14 are hard to get, Couldnt you just go to your local radio shack and get a bunch?
Anyway if they are not availble you can get them at electronics goldmine for 40 cent each I beleive.
Wed Dec 10 2008, 12:01AM
wrote ...
Is it really necessary to include swearing as part of your reply? Sure, its abbreviated, but we all know
what it means and it reflects poorly on you.
Please try to refrain from using profanity in the posts and keep it clean.
Thank you
Wed Dec 10 2008, 01:49AM
Dr. GigaVolt wrote ...
wrote ...
Thank you
Yea, sorry.
ben106
Wed Dec 10 2008, 07:45AM
I would say, I knew a part of what you wrote ;) didn't have the idea feeding the GDT with more voltage to reduce secondary windings so that it takes less space. But anyways, it's always helpful information, also for others.
