  • Guests: 68
Weird phenomenon called metal whiskers
Thu Dec 04 2008, 04:16PM Print
I just came across this Link2 and found it interesting. The mechanism behind this strange and bizzare phenomenon is not yet understood.
This is what I call a living metal! tongue
aonomus
Thu Dec 04 2008, 04:25PM
I remember reading somewhere (can't remember sadly) that the theory at the time was a small hole in the oxide forms, and the metal (tin in that paper) would be squeezed through the hole like toothpaste...
It might explain why sometimes you can take something really old that hasn't been disturbed, move it, have it stop working, clean and dust it out, and have it start working again.
Thu Dec 04 2008, 04:43PM
I wonder how the whiskers know what shape they are supposed to be, which direction to grow in, how long they should grow, when their growth should start and stop, and whether they are 'aware' of the presence of other whiskers which might retard their own development.
Does the metal lose mass to the whiskers? If so, what replaces it?
A lot to think about! cheesey
Thank you for a thought-provoking post!
Wolfram
Thu Dec 04 2008, 04:47PM
Fascinating stuff, but very annoying. I have a lot of problems with whisker growth inside my Hammond organ, shorting out switches and busbars. Some of the metal surfaces inside it are visibly hairy.
Thu Dec 04 2008, 04:56PM
Harry wrote ...
Great question! Of course the whiskers have some mass, and it must come from the metal (or not?? suprised)
I guess the only explanation is that the metal becomes hollow under the whisker...
GeordieBoy
Thu Dec 04 2008, 05:06PM
The phenomenon of tin whiskers is quite well known in the electronics industry. Up until recently it has been dealt with by the inclusion of lead into solder, and not using bright tin finish for component leadframes etc. Lead was found highly effective at preventing whisker growth. Then someone had the smart idea of outlawing lead from electronics!
I wonder if there will be a wave of electronic devices failing due to tin whisker growth to hit consumer appliances 10 years from now!
Of course life-support technologies and military applications are exempt from the move to Pb-free. So any application in which you are either trying to sustain life or promptly end it will likely not be effected! angry
-Richie,
Thu Dec 04 2008, 06:12PM
I had a little poke about on Google, and it seems that the whiskers - and how to grow them to order - are an important area of nano-materials research.
LithiumLord
Thu Dec 04 2008, 06:21PM
sorry guys, just couldn't hold :D
Thu Dec 04 2008, 06:26PM
interesting. i did hear something about them even growing through epoxy encapsulant but taking a lot longer.
I'll bet that in a few years they will probably be growing them on demand to use as inter-chip interconnects..
-A
aonomus
Thu Dec 04 2008, 07:24PM
Does anyone know if mixing non-ROHS and ROHS compliant materials will hasten whisker formation?
