  • Guests: 85
fly back driver
Hon1nbo
Fri Dec 05 2008, 03:39AM
Jamil merali wrote ...
well thanks to your help it works. I'm just using some rubber handle pliers as a "chicken stick".Anything better i could use. Plus I'm only 11 so i want to stay healthy.
I was your age when I started, but looking back i realized pliers are BAD unless they are properly rated, which is rarely the case unless you have really nice, electrical pliers made for power line workers...
mount one terminal to a solid object, that is not capable of providing a conductive path to you. Then run an HV wire (or a regular wire if it stays away from dangerous locations) to the end of a decently long wooden stick
11 and not experienced HV is a little dangerous to use mains voltage... start with the flyback driver, then move to mains.
