  • Guests: 43
pics of blown Electronics.
lpfthings
Thu Aug 26 2010, 04:12AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Had a little RGB DMX controlled LED par, it stopped working one day, Fuses was still fine, but opening it up to find this:
IMG 1956s
I haven't been able to find a replacement, anyone know where to get one? It's a THX201.
Plasmana
Thu Aug 26 2010, 12:04PM
Plasmana Registered Member #3108 Joined: Thu Aug 12 2010, 05:37PM
I have killed loads of semiconductors already, but rarely have them to fail dramatically cheesey
Heres two mosfet that exploded, and the one with an resistor on it made a heck (and I mean alot!) of smoke!
Sometimes my semiconductors gets mixed up with others - I picked out "assuming it was a mosfet and didn't bother reading the part no." from the bag of mosfets. I then connected to the drive circuitry and BAM! It turns out to be a voltage regulator...
A while ago, I was hoping to blow up a flash tube with my large cap bank for fun, but something a little more interesting happened...
Dr. Slack
Thu Aug 26 2010, 01:23PM
Looks like you managed to turn a light-emitting diode into a pair of dark-emitting monodes wink
1282829012 72 FT57865 Leds
Muttyfutty!
Thu Sept 02 2010, 09:43AM
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
dark-emitting
Wow, I love the soud of that;
"It emits darkness on the whole world Muhahahahah!!! *evil laugh*"
radiotech
Thu Sept 02 2010, 09:53PM
Wonderfull, we now know the half-light of green LED's is 240 volts.
pauleddy
Mon Sept 06 2010, 05:08AM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
well I was going about testing my new volt meter on my bank power supply which according to the volt meter puts out 1.2kv ac it work great even over the max volts of 750v until I turn it off in it flicker back on an cause a voltage spike that killed the meter, oddly it dint burn out the fuse confused and arc to a little copper rail and killed thee little things on the board and fried the contacts, so no more volt meter frown
not to self dont go over max volts on a meter and leave it plug in to a trasformer
radiotech
Mon Sept 06 2010, 06:22PM
Meters have fuses and the fuses have voltage ratings and the best meters have fuses with interrupting capacity in kiloamps on the fuse.
But the reason for these fuses and the ratings on the meters is to guarantee they wont explode if used within the rated maximum voltage .
High voltage, especially high frequency high voltage is rated with a frequency/voltage derating curve.
But all this aside, spark voltages dont care about fuses.
If you arc-over a meter whether or not it will explode into bits, in you face depends on how much energy the circuit can furnish.
I have toasted my share of expensive instruments, happily most were not mine own property. I am also aware of a Scopemeter that died whilst measuring the trend on a big SCR drive, however I was not close enough to be blamed.
Killa-X
Fri Sept 17 2010, 01:18AM
Does a blown trace count?
1284686237 1643 FT57865 4hv
I used an etched board for my 30 flash capacitor bank. This was near the positive connection, to my ring launcher. I charged it to 200V, after the 5th time, i heard a poof. Then I charged to 200V again, the SCR wouldnt fire. Discharged with a power resistor, and came to find my trace exploded! This is the reason I'm going to thick aluminum busbars!
HazzWold 1993
Sun Sept 19 2010, 01:26AM
Circuits
1284859609 2563 FT57865 Sany0188
1284859609 2563 FT57865 Sany0190
1284859609 2563 FT57865 Sany0189
Killa-X
Mon Sept 20 2010, 03:01AM
What happens when you put 300V @ 200J into a 16V capacitor...
1284951655 1643 FT57865 Capboom1
1284951655 1643 FT57865 Capboom2
