  • Guests: 52
01/12 RoV IW3IPD (63)
pics of blown Electronics.
Sun Nov 23 2008, 09:02PM
crazy4 wrote ...
wow what happened there. amazed
A bit of an overcurrent and overvoltage? Lets say, 2 kilovolts at 6 amps? tongue
coillah
Sun Nov 23 2008, 09:36PM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Dr. K, I have never seen anything like that! That's nuts!
LithiumLord
Mon Nov 24 2008, 02:09AM
Gah, bad I made no picture of the fun I had in the lab. I had to test an old Soviet AFC analizer (yeah-yeah, in Soviet Russia, the caps blow you :D). Of course I hit the switch with my very common and favorite "And now it's gonna go crraaack!" quote (came from the term of a thyristor invertor shoot-through lockup, which here is translated almost the same as "crack-through", so apparently we invented a term of "crack-out", which, of course, is a result of a transistor invertor shoot-through when they crack sending parts of the casing flying around). "Nah, why?" - my co-worker replied. The tube lighted up, I could see traces and things just felt even not to go wrong, excepting the trace slowly moving down (old capacitor leakage as I guess now) and some weird smell I thought to be dust etc (that device came from 60th iirc). After my second "How to get the goddamn trace back?!" question (the machine ignored my attempts to do it with the resistor handles) however the answer came loud and (un)clear - the blast was so loud it even rang in my ears for a while (couldn't scare me as I'm always ready for alike things). A bright shotgun-style flash, weird dense smoke with an even a bit enjoyable smell, a wasted fuse - and it's time to watch the aftermath. Was a sight to see - the floor had an oil mark of a few squares (the pattern of the ventilation grate it all was shot out through), and inside the box the huge el capacitor hull stood like a shotgun shell, with all the fill scattered all around. The biggest cap blow I ever seen!
CompWiz
Mon Nov 24 2008, 05:09AM
CompWiz Registered Member #1038 Joined: Mon Oct 01 2007, 08:02PM
I think this image is posted somewhere else too.
Induction heating with ZVS flyback driver...
Magic Smoke
Also, a bug crawled into one my ATX computer power supplies, BZZZT! Followed by smoke coming out of the vent...
Tue Nov 25 2008, 10:41AM
Here's one I asploded earlier
1227609688 30 FT57865 Igbt Explosion 1
aonomus
Tue Nov 25 2008, 04:37PM
When I was making my boost converter, I suppose the 1M dropping resistor failed, sending 400V into the comparator, which failed short, and sent 400V straight into this 555...
1024
1024
Avi
Tue Nov 25 2008, 05:12PM
I had a 555 go like that, when i looked at it under a microscope i found on the circuit inside some microscopic text TIxx (xx being 2 numbers i guess it was a year, i don't remember the numbers now)
Robert2
Tue Nov 25 2008, 07:31PM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
1227641455 1773 FT57865 Zdjcie247
Some IRFP460... I must started buying a IGBTs...
Linas
Tue Nov 25 2008, 08:06PM
Link2 amazed
jovica
Tue Nov 25 2008, 08:55PM
jovica Registered Member #1790 Joined: Fri Oct 31 2008, 10:10AM
Steve McConner wrote ...
Was this the half bridge from your DWSSTC?
Just wondering because the GDT looks very similar to the one used here Link2
