  • Guests: 57
HV doides
cduma
Fri Nov 21 2008, 10:11PM Print
cduma Registered Member #1822 Joined: Fri Nov 21 2008, 08:04PM
I have tried to look for HV diodes but, when I go to a site like mouser I find all the information confusing and am overwelmed. All I need are a few diode for a voltage doubler with a 7500v input at 30mA although I prolly wont draw that much. Its for an ion lifter
teslacoolguy
Fri Nov 21 2008, 10:23PM
Just series up a bunch of 1n4007 diodes. Link2 I would recommend about 12 series to represent each diode of the rectafier so you will need 48 and get a couple extra just in case you blow some.
Avi
Sat Nov 22 2008, 02:18AM
1n4007 is not designed to work well with the frequency range typically found from the output of a flyback transformer, but should be ok if used with an NST
Myke
Sat Nov 22 2008, 02:24AM
You might want more than 12; More like 15-17 as a guess because you want some headroom. If there is a voltage spike, you don't want all your diodes to die at once. Also the reverse voltage across each diode isn't exactly equal and so you want to spread that voltage out a bit so you also don't kill your diodes.
Sat Nov 22 2008, 12:34PM
These are not the doides you're looking for.
Sorry, couldn't resist :D
cduma
Mon Nov 24 2008, 09:44PM
Its not on a flyback. No one is going to have a flyback putting out 225watts continuos. Its a neon sign transformer. Wouldnt it be cheaper to purchase 7500v diodes instead of using 1n4007s
teslacoolguy
Mon Nov 24 2008, 09:45PM
naaaaaa for a nst 1n4007's are the way to go.
Mon Nov 24 2008, 10:12PM
cduma wrote ...
I had one running at 500W peak (>1kVA) for 6 hours on a Jacob's ladder.
...sorry, couldn't resist mistrust
Mon Nov 24 2008, 11:13PM
If you are buying from mouser, I have had good luck with the p/n 583-R5000F-T 5kv/0.2A diodes. They are nice and fast and even with 500+w at 20khz and well over 100ma of current they seemed to hold up just great smile
baleworker
Tue Nov 25 2008, 10:40PM
baleworker Registered Member #1596 Joined: Fri Jul 18 2008, 08:43PM
UF4007 are 75ns reverse recovery, 1A, 1kV diodes. They are widely available and inexpensive. Takes some time to sodler them in a string, but there is not much choice when it comes to HV fast recovery diodes.
