  • Guests: 53
Need help with flyback transformer.
cjk2
Thu Oct 16 2008, 11:21PM
More voltage is better, 24v is probably a good balance of power and sanity to start with. Ive done about 90v into a ZVS before with beautiful results tho. I would go ahead and use 18 awg or so for the primary and secondary, but that's just me. Maybe i just don't like the fact that the sharp, abrasive edges of a ferrite core tend to damage magnet wire insulation.
Chris Cristini
Fri Oct 17 2008, 12:15AM
Chris Cristini Registered Member #1749 Joined: Fri Oct 10 2008, 02:04AM
the highest i have gotten with a fly back was 36v and i was happy at least 2 or 3 inches when drawn. cheesey
Antonio
Fri Oct 17 2008, 12:54AM
1-2 cm is not 2-4 kV. Between points it's more like 10-20 kV. With a normal flyback from a small TV or monitor you will not get much more than this.
brianmay27
Fri Oct 17 2008, 02:55AM
brianmay27 Registered Member #1764 Joined: Thu Oct 16 2008, 03:52AM
oh, ok. well i will see if i can get an bigger one.
Anyway while i have you all, i have an oscilloscope but it only goes up to 200 volts like most.. Know of a way/something i can get that will allow me to measure 2-10kv? something cheep :P
Myke
Fri Oct 17 2008, 03:21AM
You can make a resistor divider from many cheap resistors and a cheap multimeter. I wouldn't suggest trying to mesure AC with it though because of lots of stray capacitance.
aonomus
Fri Oct 17 2008, 04:03AM
Voltage dividers using 10M resistors is easy, but only when you are trying to measure DC. Once you get into AC, especially at higher frequencies, it tends to go to crap.
Link2 is a nice little design, key point to note that since it uses resistors and its such a long chain, you not only introduce stray capacitance, but depending on the type of resistor you might even introduce stray capacitance (say if you use 10M wirewound resistors).
If you really need to view HV AC waveforms: Link2 might be an option...
brianmay27
Fri Oct 17 2008, 07:54AM
Ok, well i wound it with 16 gauge wire 4 times, and used hot glue to prevent the arking from the terminals. It seems to make it a bit better, I will try with a biger powersupply tomorow.
brianmay27
Sun Oct 19 2008, 01:58AM
Ok well i hooked it up to a biger power supply, however i am occasionaly geting huge arks between two pins (not even next to each other) i have hot glued them but it did not work too well.
Sun Oct 19 2008, 07:11AM
brianmay27 wrote ...
I think you didn't figure the ground pin right then, try bringing the HV wire close to the bottom of the flyback you'll see the pin it wants to arc to the most.
Antonio
Sun Oct 19 2008, 10:54PM
There is a ground pin connected to the high-voltage coil, and usually some others that are the ground terminals of one or two potentiometers connected to the high-voltage terminal and a of filter capacitor. These must be grounded too or very well insulated, or will spark.
