  • Guests: 73
Would anybody buy these items? How much are they worth?
Mon Oct 13 2008, 03:01AM
How about complete sstc's or vttc's? Maybe even sgtc's. It would all be after i have had more experience with sstc's so that i could make them better. I would be looking to sell a complete sstc with about 6 inch sparks and in a nice box for maybe 200-300 bucks. Is that a realistic price range? A sgtc would be about the same, because a good transformer costs about 50
bucks and the capacitor may cost up to 50 bucks as well, the secondary would cost me around 25 dollars and it would take awhile to tune and make work well. I would likely use a helical primary for a more compact design. Likely with solid 12 gauge. If you guys think i could sell a nicely made 2 inch by 11 inch tesla coil with something like 6-10 inch sparks, i will
go ahead and start making one.
Let me give you guys the likely specifics so you know where i am going.
6kv 30 ma nst
cornell dubilier .15 uf mmc
fan cooled copper cylinder static spark gap
helical primary with heavy gauge wire, likely solid
safety gap(OF COURSE!)
terry filter with the resistors and mov's most likely
just a simple switch to turn it on, variacs are too expensive any would add a possible 50 bucks due to the high shipping costs
2 inch diameter secondary with 11 inches of winding and 30 gauge double build wire with a few(maybe 5 or more) coatings with minwax clear coat fast drying polyurethane
little 12 volt rectified and smoothed transformer for powering the fan and a light to indicate it is on
rfi fliter
Just for the heck of it i will tune it with a small really cheap topload(a ball covered with aluminum tape) before selling so that when you get it you just plug it in and flip the switch and watch the sparks fly. I would use and atx psu fan, bought from either radio shack or a local electronics store called Ralph's electronics . I would include a 2 amp variac, but i would have to have two power cords going to the tesla coil, one for the variac controlled nst and one to the 12 volt transformer. I am just trying to make some money before i can get a real job. Even when i have a job i would still like to make a little money on the side.
No, i do not really think i would be able to sell it for this much or even at all, but ya never know!
Ok, how about an 811a vttc?
Same secondary specifications as above
one 811a
a fan to cool the innards
a plate transformer(no mot's here!) of about 1500 volts so i do not overheat the 811a over long runs
a proper filament transformer
thick and tight wiring
tickler coil(feedback coil) will be painted over several times to be sure the thin insulation on the enameled copper wire does not arc over
811a socket
made with Steve Wards schematic
good 1nf 20kv capacitor, probably doorknob
fan cooling the plate transformer and doorknob cap
811a top cap
if i can get it to work well, simple interrupter(with a single 555 and mosfet to ground the cathode) for cool sound effects and sparks will differ with different frequencies, and gdt would be used to keep 555 away from any spikes. Got this idea from someone that use a mosfet to audio modulate a vttc
of course the 12 volt transformer, rectified, smoothed, and regulated for the fans, interrupter, and of course a convenient led or other light to indicate power on
and lastly, an rfi filter for the input
This is the point where people think i am crazy :P. I would not make many of these coils, cause i doubt there are many people that would buy it, especially for the price that i want. These prices would only leave me with 50-100 bucks profit(which is really alot), because of the fact that the components are quite expensive. I do think the sgtc should sell, especially with such good capacitors and filtering! The shipping will cost an arm and a leg, but this would be a cool thing to have for impressing friends, showing how you can light a fluorescent bulb from a distance, and turn a regular light bulb into a plasma globe.
Chris Cristini
Mon Oct 13 2008, 05:19AM
Chris Cristini Registered Member #1749 Joined: Fri Oct 10 2008, 02:04AM
u can maybe make small and safe plasma globes no?
Mon Oct 13 2008, 05:25AM
crazy4 wrote ...
Not exactly.... I can make the high voltage power supply but i have no gas or flasks or anything that would work. I can make plasma in a little bulb but not much and it is not efficient.
Chris Cristini
Mon Oct 13 2008, 05:29AM
just a thout smile
Wed Oct 15 2008, 01:04AM
So... Anyone have an answer for me? Sorry i just cannot help but ask. I wanna know if it'd sell sooo bad.
rp181
Wed Oct 15 2008, 02:43AM
nothing but to do but make one and put it on EBAY, make sure you put lots of details.
Dragon64
Wed Oct 15 2008, 02:45AM
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
OT here but,
If money is what you want, I suggest *cough* paid bogging advertising survey *cough*
25¢ or $3 for surveys and paid blogging might seem low but they add up quickly.
I get around 10 paid blogs a week each $2 to $5 ($20 to $50) a week for doing nothing.
